Old 01-19-2021, 01:37 PM   #1
Brake and Bearing Service Options
I have a 2019 Alpha Wolf and want to repack the wheel bearings and check the brakes before I start heading back out this spring. Camping World seems really expensive for service. Are there better options for service? I was a licensed mechanic back in the 80ís and 90ís. Is repacking or servicing my TT really that different than old Chevyís? Thanks for your advice.
Okietraveler is offline   Reply With Quote
Old 01-19-2021, 01:52 PM   #2
No different than back in the olden days. Make sure you get new seals and the proper grease.
Often times places that sell utility/dump/landscape trailers will do the work way better and much cheaper then places like Camping World. Lots of Truck Repair Centers service bearings/brakes on ALL trailers too.
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 01-19-2021, 01:55 PM   #3
Do you have a tire dealer you trust? Ditto for a private repair shop.
Even an RV mobile service.
Wheel bearing packing really hasn't changed since tapered roller bearings were introduced. Download the instructions from Dexter's website, read through, and tackle it yourself. If you adjusted wheel bearings on an old Chevy with tapered roller bearings you're good to go on trailer bearings. Double ready if the old chevy had drum brakes.
Only thing that's really changed is the newer axles often don't use a castellated nut and cotter pin. They use a locking "clip" that is just pressed (by hand) onto the end of the spindle locking the nut in place with fingers and a flat spot on the spindle.
Just wear clothes you don't mind getting dirty
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 01-19-2021, 04:18 PM   #4
Lins's Avatar
This! The big issue knowing what preload, or lack there of, the bearings need.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 01-20-2021, 01:38 PM   #5
SetauketJeff's Avatar
My dealer (over 1000 miles away), who had the shop run me through the TT when I picked it up, told me that they advise the following: Repack annually, if the shoes on an electric brake look worn, it's best to replace everything. Their experience is that electric brakes have a high failure rate, and for a few bucks more, change everything. They knew I was a motor head and going to perform all the work myself. They added that they advise their customers who have them service their TTs to have them, the shop, change out the entire system.
Honestly, this is my first time dealing with electric brakes. What is everyone else's experience?
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2007 Chevy Trailblazer LT 4X4 Tow Package, Locking Rear, 157K Just pulled 16FQ 1,044 miles. Husky Centerline TS32215 WDH Round Bar 400-600Lbs.
CURT 51180 Echo Bluetooth Brake Controller (Love it!)
2004 Ford F-150 STX 4X4 Tow Package, 206K For Pulling TT in the sand
SetauketJeff is online now   Reply With Quote
Old 01-20-2021, 01:51 PM   #6
Trailer Park Supervisor
NJKris's Avatar
I'm a driveway mechanic and did it myself. I had an easier time than when I did it to my 1980 Triumph Spitfire 35 years ago. I agree with other poster than any mechanic worth his salt can do it. Would not take it to a dealer.
NJKris is offline   Reply With Quote
Old 01-20-2021, 03:34 PM   #7
I've repacked a LOT of bearings on axles with electric brakes and have yet to replace 'everything' other than the seals and any bearings/races that looked suspicious.
Sounds like the shop was prepping every potential customer for spending big bucks whether needed or not.
Unless your brake controller is improperly adjusted or you have an actual issue, electric brakes do not have a high failure rate nor wear out any quicker than any other kind of brakes.
Old 01-20-2021, 03:39 PM   #8
Lins's Avatar
Agreed. I have had to replace 2 brake magnets because the wires broke off right at the magnet so couldn't be repaired easily. One reason to ensure your tires are balanced as a lot of shops won't balance trailer tires unless you ask. I don't see any reason to replace the whole assembly.
1953 GMC 9314
Old 01-20-2021, 03:50 PM   #9
Was referring to the brakes with regard to replacing everything, not the repacking. Sorry if I wasn't clear about it. Am asking about replacing the entire brake units when pads burn down. As I don't have any experience with electric brakes. Shop knew I was not having them do any of the work (1000+ miles away, and am my own mechanic). And yes, does sound suspect...
2021 Wolf Pup 16FQ.
Old 01-20-2021, 04:42 PM   #10
Thanks all. Your feedback was exactly what I was looking for.
Old 01-20-2021, 04:56 PM   #11
Thanks for the clarification, I did misunderstand.
I haven't bought brake shoes in the last 5 years but there were a few posts recently (last year) of someone on eBay selling backing plate assemblies, pre loaded with shoes and magnets for a pretty economical price. If you shop around you may just find them comparable.
Old 01-20-2021, 05:58 PM   #12
Just be aware that there are differences, if replacing Dexter self adjusting brakes, and what many online sources are selling.
The adjusting mechanism's are different on the cheaper units and can lead to undesired results.
Traditional self adjusters operate only in reverse. Since backing while braking is far different with trailers Dexter auto adjusters are designed to use forward stopping.
2004 Nissan Titan
Old 01-20-2021, 07:24 PM   #13
With your background you'll be the one giving advise about how to repack trailer bearings soon enough.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 01-22-2021, 02:27 PM   #14
Do I hold the bearing in my left hand or right?
2021 Wolf Pup 16FQ.
Old 02-16-2021, 05:20 PM   #15
SilhouettePenny's Avatar
Etrailer.com will provide everything you need to replace or repair electric trailer brakes. Watch a few YouTube videos and then grab you handy dandy mechanics tool set and a roll of paper towels.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 02-16-2021, 05:48 PM   #16
Just as confused as you
Scrapper's Avatar
Neither, dump the grease on the ground then drop the bearing on the grease blob and step on it. Remember to take your shoes off before walking on the brand new white carpet your DW just had installed.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 02-16-2021, 06:14 PM   #17
Don't laugh, I've been in some houses that the carpet looks exactly what someone did. Oh, If the carpet was ever white it was 20 years ago
Oh yeah, he living room smelled like old gear oil.
2004 Nissan Titan
service
