Originally Posted by babock
Buy a new magnet and a new drum.
Why would you do that without measuring wear? Those friction marks will come up the very first time you brake. Maybe even while you are setting the brake controller as you pull out on the trip, one block from your house.
You wouldn't change the pads or shoes on your car after making one stop, would you?
Perfect example why you pull your drums yearly.
Even changing brakes after one year doesn't make sense if they aren't worn below spec.
Larry
