Breakaway switch question
I visited our 2005 Forest River Wildcat 25RKS at its storage space yesterday, and noticed that the breakaway plug was pulled out of the switch. I can only suspect that the yard maintenance crew snagged the wire with their weed eater equipment and pulled it loose from the switch.
Since this may have happened weeks ago, what is likely to have happened with the electric brakes applied for such a long time? The trailer has two Group 24 deep cycle batteries in parallel, and is always plugged into shore power when in the storage yard, so the converter/charger will keep them charged up and would provide plenty of amps to offset the drain from the brakes.
I haven't brought the tow vehicle to the trailer to test the brakes. I think I'm most concerned about the electric coils in each brake burning out, or possible something upstream failing, such as the brake wiring or possibly the breakaway switch itself.
If I was to test continuity of each coil, what resistance should I see, assuming each coil is disconnected from the system for testing? If it's open, that would be obvious.
