Originally Posted by Outsider
Thanks for the info.
Yes, the Escape flashes at startup and then goes solid ON until the vehicle is switched OFF.
The F150 does all kind of odd things.
May flash for a while at times.
May be ON solid for a while at times.
May be OFF for a while at times.
Yeah, you may have 1-4 sensors bad. That flashing is a fault code. Are you still using the OE sensors which would be very good to have lasted this long. Your Ford truck may have the banded type sensors, which you can replace with the valve stem types. Cheaper and easier.
Even if have one sensor bad, you may be looking at replacing the rest in short order.
