Old 01-13-2021, 11:26 AM   #1
Castlerock to Goodyear
Hi all! Hopefully I can get a quick response...
We have a 2018 Rockwood 9206ws which has the original Castlerock tires. Those tires are 225/75 r15 load D.
I am looking at replacing with Goodyear Endurance but they look to be load E.
Will this be a problem in any way? To my understanding load E would be heavier duty than the load D I currently have, right?
Crookedhalo and Hubs
2018 Rockwood Ultra Lite 2906ws
TV: 2019 F150 XLT w/max tow
Crookedhalo is offline   Reply With Quote
Old 01-13-2021, 11:49 AM   #2
Thurman's Avatar
My opinion based on experience: Replacing the Castle Rock tires is a good thing, I replaced the Castle Rock tires on my TT after having it for one year with Goodyear Endurance load range "E" tires. Actually I cannot tell any difference in towing but I feel better about the tires knowing they are a better tire and the load range was increased. I researched the Goodyear tires and found out that Goodyear recommended that I run those at 70 PSI. I have had no problems with the Goodyear tires after four years now.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 01-13-2021, 11:51 AM   #3
You are correct. The load range E may require higher air pressure though. This may only be a concern if you carry a small portable inflator. If it’s old and tired it may not be up to the task.
WanderMore is offline   Reply With Quote
Old 01-13-2021, 12:22 PM   #4
I have a similar set up to yours. Last year I replaced the Castelrock d load with Goodyears e. I run them at 80 psi cold and so far I like them.
The tires look much better. Almost no flattening where the tire meets the road and you'll find out that the distance between tire is going to increase a little bit.
pibi is offline   Reply With Quote
Old 01-13-2021, 12:28 PM   #5
I did this very thing about 4 years ago now, posted a thread about it then and there have been a myriad of other threads where folks have done the same.
I run mine at 74 PSI (for my load - follow Goodyear's load chart for YOURS) and I recommend you put metal stems in the wheels.
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 01-20-2021, 11:59 PM   #6
Mwjaco's Avatar
Had a catastrophic failure today. Castle Rock on my 2020 Cherokee Wolf Pack. Trailer is lightly loaded and have towed less than 1000 miles. In all fairness to Castle Rock, I have no idea what caused this and surprisingly there was no physical or audible indication the tire had gone. A fellow motorist alerted me. There was moderate traffic on I-5 as it was around 3:30 this afternoon when I was passing through Albany Oregon. I had stopped at a rest stop to stretch about 15 minutes earlier, however I didn't notice any issue so my conclusion is road debris.
I'll be calling the local Goodyear store here in Eugene tomorrow to see if I can get a set of GY Endurance installed Friday. Click image for larger version
KD7PSN Clark County ARES Team 3
Vancouver, WA
2020 Cherokee Wolf Pack Platinum 23Pack15
2013 F150 Screw 3.5L Eco
Mwjaco is offline   Reply With Quote
Old 01-21-2021, 07:00 AM   #7
I'll be calling the local Goodyear store here in Eugene tomorrow to see if I can get a set of GY Endurance installed Friday. Attachment 246353
Wow! Glad everyone is safe and no major damage to your rig! Might have been a defective tire (hopefully) as our rig still has the original tires from late 2017 build on it. Have no idea how much mileage original owner put on them, but I know we put at least 1500 miles on between May and November of 2020!
Old 01-21-2021, 08:26 AM   #8
Airdale's Avatar
Being the same designated size as the OE tires makes the LRE a good replacement. You need to confirm your wheels are rated for the 80 PSI needed to get maximum load capacity from the LRE tires. I second the earlier recommendation for steel valve stems and metal caps.
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 01-21-2021, 08:56 AM   #9
Good example of why a TPMS is necessary.
Even with my TPMS, I can see all 4 tires in my mirrors and glance at them often.
Old 01-21-2021, 09:06 AM   #10
badger5301's Avatar
Add us to your list of those that replaced the Castle Rocks with Good Year Endurance. With our weight according to the Good Year load chart we run ours at 74psi. Did get the metal stems and a tpms system.
badger5301 is offline   Reply With Quote
Old 01-21-2021, 10:00 AM   #11
SailorSam20500's Avatar
Just a reminder to everyone talking about the pressure they are running. According to the US Tire & Rim Association who is the source for all tire pressure guides for US designed tires. The pressure on the charts is the MINIMUM pressure required to support the given load. That is not the recommended pressure.
Are you basing your pressure based on 1/4 of the total weight of your trailer? I can pretty much guarantee that you have different actual loads on each tire. You should be running pressures based on the most heavily loaded tire. From what I've read, the difference between highest and lowest loaded tire is probably over 100 lbs. I know it is on my trailer because I had RVSEF do an individual wheel weighing - 8 individual weights for my truck and trailer.
For my trailer, there was a significant difference between tires on the same axle and between front to rear on each side of the trailer. Surprising to me, the front to rear difference was opposite by side - LF heavier than LR and RF lighter than RR.
Al
Save the Earth. It’s the only known planet with Beer.
When everything is coming your way, you're in the wrong lane.
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 01-21-2021, 10:36 AM   #12
badger5301's Avatar
SailerSam,
I do run ours based on the 1/4 method you mention but I go up a couple psi to give a cushion. According to my cat scale sheet our trailer axles are at 8280Ibs with a fully loaded truck and trailer. 1/4 of that puts me at 2070Ibs per wheel which according to the Load/Inflation chart would be around 50psi. That seems very low to me on a tire rated for 80psi. I run ours at 74psi which gets me into the 2700Ib per tire area which gets me into the 10,800Ibs category.
I'm here to learn so if I'm doing something wrong any advice would be greatly appreciated.
Old 01-21-2021, 10:42 AM   #13
Although the Goodyears are rated to carry 80 psi this does not mean they require that much pressure. Pressure should be based on the trailer weight. I run 70 psi.
I made the decision to upgrade to Endurance last summer while changing a blown Castle Rock while on the shoulder of I-20 in 100 degree heat while big trucks were shaking my camper. Two hours later I had four new tires, a second spare, and tremendous peace of mind!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 01-21-2021, 11:34 AM   #14
Originally Posted by badger5301 View Post
SailerSam,
I just find it interesting. The number of folks who publish that you should have a 15-20% reserve margin on the weights your TV is able to pull and also run tires at the minimum for the weight. Personally prior to replacing my tires due to age I was running at >25% over my tire capacity and by upgrading the load range of the tires and the inflation I'm using and am now somewhere around a 50% margin.
From info on the Airstream forum, I saw a post that said Airstream has started installing GY Endurance tires as OEM. When they did, the Airstream increased the recommended pressure to the max cold inflation for the new tire. I know FR posted the recommended pressure on my trailer as the max CIP - giving me that 25% margin.
FWIW, I'm now running with a 50% margin. At some point Roger Marble the guy who runs a RV tire blog flat out recommended that towables always run at their tires max cold inflation.
Also as a point of info, from my weighing, the actual difference between max and min weights per tire was 200 lbs side to side. From the tire inflation guides I've looked at, that means increasing the pressure by at least 5 psi. Note that front to rear the difference was 150 lbs. That was the front tire on one side and rear on the other.
I've also thought about the load placed on a tire while running and going around a bend. Given the geometry of a trailer I suspect it could get quite high. Just things to think about.
Al
Old 01-21-2021, 01:56 PM   #15
Is that a fact about the 70 # I recently traveled to Florida. With the tpms system I noticed that the pressure started to ramp up to almost 100 pounds. I released to 90. I did have 80 cold when I left Michigan
MichaelW is offline   Reply With Quote
Old 01-21-2021, 02:05 PM   #16
Never adjust tire pressures on a tire anytime other than when it's cold. (not driven and not setting in direct sunlight)
Tire pressures will rise during driving. That is normal and tire manufacturers take that into account.
Old 01-21-2021, 02:25 PM   #17
Thank you for your help
Old 01-21-2021, 07:56 PM   #18
Definitly consider installing a TPMS.
People tend to blame the tire failure on tire brand name but it could well have been caused by a simple puncture that went unnoticed until tire got hot enough to come apart.
It's often hard to feel a trailer tire losing air as it's not as close to the drivers behind to feel like if a TV tire was going flat.
A TPMS is a lot quicker warning system than a passing motorist. Often quick enough to stop, put on spare, and still have a repairable tire.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 01-21-2021, 08:28 PM   #19
Mwjaco's Avatar
Sounds like TPMS is more than a luxury. I'll be researching that next.
Vancouver, WA
Old 01-22-2021, 08:33 AM   #20
Yes, going up to load range E is a good idea, but you need to know your weight on the tires and adjust your psi downwards as indicated on the tire mfrgs. table.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
