Old 07-24-2018, 02:04 PM   #21
Oaklevel's Avatar
I have never had this to happen but by the posts this appears to be a GMC / Chevy issue ?????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-24-2018, 02:20 PM   #22
nomad297's Avatar
It is. It is a well known issue with GM trucks from what I have heard from several mechanics and from online research.
Bruce
Old 10-17-2018, 05:32 PM   #23
I've had failed brake lines on a 2001 F250, a 1993 Jeep Wrangler, and a 2004 Chevy Silverado. All rusted through and fortunately I found dripping fluid on all while stopped. The culprit of course was rust. The Silverado rusted through on the driver side on top of the frame rail back by the fuel tank. No way to inspect reliably. This is or certainly was an industry problem. I believe most customers would be glad to pay a little more for lifetime brake lines. At least customers who keep their vehicles like I do. I pull a Cardinal 5th wheel and I've had it all over the country including Alaska so I feel fortunate to not have had this happen on one of my trips.
luvbigiron is offline   Reply With Quote
Old 10-17-2018, 06:57 PM   #24
Had it happen and n my 98 Frontier as well.
Make sure that you do a good inspection. You will find other bad spots as well.
Bob
HappyTrav is offline   Reply With Quote
Old 10-18-2018, 08:53 AM   #25
Always something to keep an eye on. Thanks!
Cagiva is offline   Reply With Quote
Old 10-18-2018, 09:22 AM   #26
Denver To Yuma In 90 Days
Three times for me...
I had a front brake line burst on a 1977 Dodge van I had that was about 10 years old...tried to stop at a red light and heard a pop...brake pedal went all the way to the floor...glad nobody was going through the green light on the other street as I couldn't stop!
Ironically, there was a small mechanics shop right there on the same corner and I turned in, left the van there as I lived about three blocks away and walked home.
He had it fixed by noon the next day...it was a rusted out brake line!
Also had the same thing happen to a 1987 Dodge van, although I was lucky that it burst just as I had pulled into my driveway.
This van was the best vehicle I've EVER owned in my life...I saw it still on the road about five years ago in Thornton, Colorado!
Both of those happened in Michigan...the 'Salt-On-The-Road' capital of the world!
One more time (in Colorado), on a 1987 Buick Century...was on my way to work and going through a green light when suddenly the guy in front of me in a Chevy or GMC pickup just stopped in middle of the intersection.
I hit my brake pedal hard and POOF...to the floor, although this brake line was a rubber one!
The only thing that kept me from slamming into the back of that truck was the left turn green arrow was still on and I barely missed the back of that truck by maybe a foot, made the left turn, slammed through one of those Colorado water drain-off dips in the road and bottomed out the car, and came to a stop on the side street.
I was about a mile from home so I limped back to the house using side streets.
JohnD10 is offline   Reply With Quote
Old 10-18-2018, 09:49 AM   #27
clr
This seems to be a problem with the RAM and Chevy trucks. Every friend of mine with a RAM has had this type of problem once the truck has some years on it. Both use a steel type brake line that is prone to rust over time. Only Ford that uses a cooper zink alloy type brake line that is not prone to rust like the others seems to not suffer from this problem.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 10-18-2018, 10:03 AM   #28
I owned my 1996 Dodge Ram 1500 5.9L Magnum V8 motor for almost 18 years and other than brake pads, filters, tires, catalytic converter, battery, stereo and speakers, U-joints, shocks, radiator, hoses and water pump...it was all completely still stock parts from the factory!
It was my most favorite vehicle I've ever owned...loved it to death, but my ex wouldn't let me keep it when I got my new truck!
If you live around Rochester, New York...the guy I sold it to in Colorado is still driving it with close to 250,000 miles on it.
Last time I got a text from him he said that he finally did have to put a new transfer case on it.
Old 10-20-2018, 04:21 PM   #29
Lins's Avatar
Sorry but I find this hard to believe. Unless you have a single master cylinder like our ‘53 GMC, you don’t lose all your brakes at once unless the whole system is just neglected. If you lose the front brakes, the rear brakes should still work and vice versa. As an example, I’ve had the front brakes lose fluid on a ‘69 Firebird I used to have, but still had rear brakes and some pedal pressure.
Lins is online now   Reply With Quote
Old 10-20-2018, 05:08 PM   #30
nomad297's Avatar
Originally Posted by Lins View Post
Sorry but I find this hard to believe. Unless you have a single master cylinder like our Ď53 GMC, you donít lose all your brakes at once unless the whole system is just neglected. If you lose the front brakes, the rear brakes should still work and vice versa. As an example, Iíve had the front brakes lose fluid on a Ď69 Firebird I used to have, but still had rear brakes and some pedal pressure.
Believe it!
I had it happen on a 2004 2500HD and on a 2005 3500HD. One year apart from each other.
Bruce
Old 10-20-2018, 05:10 PM   #31
Lins's Avatar
Originally Posted by nomad297 View Post
Believe it!
Bruce
Brake failure I believe but pedal shouldnít go all the way to floor with zero resistance at all
Old 10-20-2018, 05:47 PM   #32
Scoundrel
HangDiver's Avatar
There's something to be said for old technology.....
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 10-24-2018, 11:34 AM   #33
If it ever happens to you...then you'll surely find out!
Old 10-24-2018, 11:37 AM   #34
Lins's Avatar
As my previous post said, I've had it on a '69 firebird I had. The pedal still had resistance near the end of the travel for the rear brakes as front and rear brakes are separate circuits which vehicles have had for decades. Our '53 GMC currently only has a single brake circuit which would do as you apparently experienced.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Old 10-24-2018, 12:22 PM   #35
llr
In theory you are correct, at least many times that is not the result.
Recently blew a brake line in a 2003 Durango, technically it still had some braking as there was some drag with the pedal on the floor however if I put in in neutral I am guessing it would take most of a block to stop from 30MPH.
I also had a 1994 class A on an F53 that the brake fluid boiled. Again one line so should of had brakes left. I could not detect any braking effect with the pedal on the floor or pumping it.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is online now   Reply With Quote
Old 10-24-2018, 12:41 PM   #36
Mr Towed's Avatar
Right as we were pulling into our site in Maine, my wife was outside spotting the trailer because it was a tight turn, and the pedal went right to the floor! I said, "um, I think we just lost the brakes in the truck." We got very lucky because for one, we were not traveling at highway speed, two, we had reached our destination, and three, we still had trailer brakes and the parking brake to stop us. We took the island explorer bus (awesome FREE service supported largely by LLBean) for our planned trip the next day, and then we took it to the airport to rent a car to do some parts running. Got a piece of terminated brake line and bent it up myself, we also got a little $5 bleeder kit which helped a lot and we were back in action with only about 2 hours under the truck. Oh, the other reason we were lucky was that the cause of the brake failure was a pinhole on one of the hard lines on the rear axle - really easy to access, no jacking or tire removal required.
ID:	189891   Click image for larger version
ID:	189892   Click image for larger version
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline   Reply With Quote
Old 10-24-2018, 12:52 PM   #37
Iwannacamp's Avatar
I have no dog in this fight, but maybe in a panic stop(as noted) and 60%(std disk/drum ratio)brake failure with a substantial fall in pedal height would lead one to remember a "brake system failure"
2017 Puma 297RLSS
Old 10-24-2018, 01:03 PM   #38
RV There Yet?
IsleDog's Avatar
Until it actually happens to you, you wont know how it feels. I have had the rubber lines swell internally, locking the fluid inside and slowly seeping back out. this caused the truck to pull to the side while accelerating. have had locked up calipers, thats fun. i have also had a rear brake line that failed and was dripping fluid. we were trading it in for a truck 600 miles away. found out half way there that we had a problem. ours felt like there was pressure there, but in stop and go traffic, you could feel the peddle start dropping to the floor. kind of spooky.
its a mechanical system that can be fixed fairly cheaply compared to a new vehicle. it would be worth it to have the brake system inspected and lines replaced as they are needed. you can also have them give it a good going through to give you back that piece of mind.
IsleDog is online now   Reply With Quote
cat
