08-02-2021, 11:37 AM
#181
Negotiate a tire change as part of the purchase.
The RV dealer can replace brands. However, they are prohibited by regulations to change designated sizes. The regulation is an across the board regulation applicable to all vehicles built under the guidance of FMVSS (standards). It reads; tires on the vehicle at the time of first sale MUST be the same size as those identified on the vehicle's federal certification label.
Note: A ST225/75R15 LRD can be changed by the dealer to a LRE. Load ranges are not part of a tire's designated size and the LRE will provide an identical load capacity as the LRD at 65 PSI.
A Trailer Tire Poster
08-21-2021, 07:01 AM
#182
08-21-2021, 10:23 AM
#183
Not sure about that one. Dealers change tires and wheels for customers or even for showroom vehicles before you buy. They install larger ones of course not smaller. Just go in any new vehicle dealership and look at the Ford, Chevy, Jeep, and Ram 4X4's. You may see several with lift kits and larger (different) tires than the label specifies. I suppose we should call the tire police?
08-21-2021, 10:42 AM
#184
Originally Posted by krazyk
Not sure about that one. Dealers change tires and wheels for customers or even for showroom vehicles before you buy.......I suppose we should call the tire police?
Airdale is correct. Regardless, people do the opposite all the time. The bottom line, I think, is that most of us, if not all, increase tire capacity to ensure a better margin of safety, carrying capacity and stronger tire. So, no harm, no foul, other than not being IAW the regs. I can't recall anyone ever saying they were looking to put a worse tire on their RV.
08-21-2021, 03:47 PM
#185
Automotive vehicles often have more than one option approved by the vehicle manufacturer.
RV trailers seldom have optional tires offered. When they do they will be installed before first sale and the certification label will refelect the change.
For dealers, changing wheels and tires without vehicle manufacture approval before or after first sale is very risky. They would become responsible for any material failures linked to the unauthorized tire/wheel changes they made.
08-21-2021, 05:03 PM
#186
Thats absurd. So you think the trailers are safer with Castle Rock trash than a dealer installing Goodyears as part of the sale? You can't be serious. For example my 27RR came with 205 / 14 load range C, Castle Rocks new. I quickly changed that to 215 / 14 load range D Goodyear Endurance. So my trailer is now less safe?
No logical person here is going to listen to your tire advice. You should stop trying to confuse people who are making their trailers safer.
08-22-2021, 12:57 AM
#187
Thats absurd. So you think the trailers are safer with Castle Rock trash than a dealer installing Goodyears as part of the sale? You can't be serious. For example my 27RR came with 205 / 14 load range C, Castle Rocks new. I quickly changed that to 215 / 14 load range D Goodyear Endurance. So my trailer is now less safe? Your trailer is out of compliance with its federal certification label. A well trained tire installer would not have let that happen.
I did not mention brands and neither do the regulations and standards. Brands are a personal choice.
The selling dealer MUST comply with the following statement. A violation by them could cause an entire model recall action.
The following statement reefers.
FMVSS 571.120 paragraph S10.3: The tires on each motor home and RV trailer at first retail sale must be the same size as the tire size on the labeling.
There is a lot of hearsay information about tires and wheels. I try very hard to stick to the facts.
08-22-2021, 01:20 PM
#188
I read your comments a lot and it seems like each one is hung up on "at first retail sale".
Once the paperwork is signed that is the first sale. After this point if a customer chooses to change tires there should be no issue. No different than changing tires 1,000 miles down the road. Its now considered an aftermarket part in my view. If the new tire grenades there is no warranty to fix it either way (OEM vs aftermarket). The customer will have to lean on their insurance policy to repair the damages.
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
08-23-2021, 01:51 AM
#189
My responses to tire issues are about what is supposed to happen and is based upon information from the governing body (NHTSA & their standards wing, FMVSS, the Tire & Rim Association (TRA) the US Tire Manufacturers Association (USTMA). I also use PDF information from well established tire manufacturers.
There are procedures for just about everything tires. Let's say a consumer changes out their ST235/80R16 with ST235/85R16. By all tire industry standards that's called "plus sizing". There are procedures for that action that protects the field and re-validates the tire placards. Those that don’t use the proper procedure have no recommended cold inflation pressures except those that satisfy them on each event.
Tire warranty information is mandated by NHTSA to be published in the vehicle owner's manual. It must provide the tire brand name, Manufacturer/wholesaler and a valid contact address/phone number.
09-20-2021, 01:17 PM
#190
damn china bomb got one of my renters this weekend. first timers. felt bad for them, they were so nervous to the point of asking me if i was nervous. im convinced sometimes people wish it upon themselves. luckily they chose the top insurance tier, but not sure what more itll cost over the deductible.
fwiw - 2 year old popup, nothing loaded but the empty camper itself. not sure how fast they were traveling, it detonated on the interstate with 70 mph speed limit so speed couldve been a factor. Ridgeway sport st145r12
pics uploaded all crazy angles just rotate your monitor
09-20-2021, 01:26 PM
#191
Trailer Park Supervisor
I'm beginning to think Kevlar wheel wells should be mandatory equipment.
Yes, I drink the water!
10-15-2021, 10:05 PM
#192
If I recall, they were Firestone 721 tires and they were manufactured incorrectly. I blew up two of them in twoTroop Cars I was driving. Scared the crap out of me both times.
10-16-2021, 12:05 AM
#193
According to some old internal memos the 721's were being produced with little or no prior testing. This right after the largest recall of tires in history, the Firestone 500.
These two "events" are believed by many to have brought about the end of Firestone of old and Bridgestone taking top billing on the signage.
The 70's were a bad decade for tire mfr's as radials were taking over the market. US manufacturers wanted to build them like they did the tires the companies were built on but they eventually had to learn from the Europeans who'd pretty much perfected process by then.
10-16-2021, 06:32 AM
#194
I have about 1000 miles on my 2021 Surveyor but after reading this thread and others like it I decided to change the tires. I was able to snag 2 Endurances at my local Discount Tire at a reasonable price. I will get a Carlisle for the spare.
in talking to the very nice man at Discount, he said someone had brought in a Castle Rock recently that was a spare, 2 years old, always under the spare tire cover, that randomly self-destructed. he also said that Goodyear had recently allocated their remaining stock of Endurances to Discount tire and OEM's.
11-01-2021, 05:35 AM
#195
in case you thought this was an anomoly
Other tire blew on a different renter about a month and a half later, 3 rentals later. Of course I’m diligent about pressures and checking the tires before it goes out. No other damage thankfully. Taking all 6 China Bombs on all my campers out of service today for good tires. This is a 2020 model year camper!!! maybe 2000 miles on it. I thought it was a joke when the dealer called them that to try to sell me extra warranty. Unbelievable!!!
11-01-2021, 08:37 AM
#196
Rental? Smaller, light, trailer?
Guessing the issue is not your diligence in taking care of the tires but rather the renter's ignorance regarding towing speed. I see small travel trailers passing me when I'm not towing and cruising along at 75 or so.
You know the expression " drive it like you rented it"?
Want a real eye-opener? Install a hidden dash-cam with GPS and large SD card. When returned pull the card and look at speeds shown on recordings. A dash cam is probably cheaper than other gps devices used by fleets.
Car rental companies started doing this years ago and fine (per contract) renters for excessive speed.
11-01-2021, 08:49 AM
#197
I guess anything is possible but doubtful with this couple, they were season citizen retired couple. Tires are rated for 70mph I would hope this rating had some safety factor built in. Also, both blowouts happened within a month of each other, after 2 years of travel.
Regardless all 6 stock tires will have been banished to the boat dock by this weekend.
PS i believe the saying is drive it like you stole it
11-01-2021, 10:05 AM
#198
Brand would help. Not all tires made in China become bombs.
11-01-2021, 10:43 AM
#199
posted in an earlier post. ridgeway sport without the nuclear head option
other camper's castlerocks that will be changed preemptively with goodyears
11-01-2021, 11:13 AM
#200
Unless you are Tony Beets, the much censired character on the Discovery Channel's "Gold Rush". That was advice he recently gave his daughter.
Having been a frequent renter of cars in my career I can attest there is truth to that.
As Tireman9 has pointed out numerous times a tire failure often has it's genesis many miles prior to it's "exodus" where the tread leaves.
