Originally Posted by Domer1972
We're on the road and just noticed a crack in one of the rear tandem tires on our Class A. It's about 1 cm deep. There is no bulge or loss of pressure. Treads are good. Tires have about 29,000 miles on them and I was planning on replacing all upon return from this trip and before our next one. Could use an assessment of the risk involved with continued travel. I've attached a picture of the crack.
You are making me do math way too early in the morning.
25.4 mm to an inch, so 2.54 cm to an inch......so maybe just a hair over 3/8ths of an inch.
It looks more like a cut with diagonal path like that than a true rubber crack. You need to take a flat head screwdriver and kind of pry it open somewhat. If you can see any cords/steel wires...it needs to come off for sure. If you don't see any, you probably can just continue on.
