Old 11-25-2020, 02:29 PM   #1
Cracked frame! Help
Crawled under my Forest river Grey Wolf, 22RR today. Noticed a cracked frame crossmember, looks like it holds a tank up. Maybe structural too. How bad is this?
ID:	243650   Click image for larger version
BrianF is offline   Reply With Quote
Old 11-25-2020, 02:32 PM   #2
Kcoulter's Avatar
Pretty bad, but a decent welder can fix you right up.
2020 Flagstaff Micro Lite 25BRDS
2021 Ford F-350 XLT 6.7L Power Stroke
Kcoulter is offline   Reply With Quote
Old 11-25-2020, 02:37 PM   #3
It certainly can be fixed by jacking that crossmember back up in place and plating both sides.
Do you recall hitting a pot hole or something to cause that?
It took some force to crack that crossmember vertically.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-25-2020, 04:20 PM   #4
Lins's Avatar
Serious but easily fixable. I'm more concerned with what's going on with the rest of the underside in the first pic.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 11-25-2020, 06:31 PM   #5
Just as confused as you
Scrapper's Avatar
There's no maybe about it, that is a structural crossmember. With that cracking, I wonder how many rv's with enclosed underbellies have cracked crossmembers.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 11-25-2020, 07:43 PM   #6
Frame damage
How old is your trailer? your frame may have a warranty. Looking at the the belly pan cover or what ever you want to call it you may have run over something and that might be insurance.
Fish N Farm is offline   Reply With Quote
Old 11-25-2020, 08:02 PM   #7
Yep you need to get it fixed soon. I don’t see any damage the other posters are thinking they see. I see your underbelly skirting is all I see. Anyway you need to look at your spring shackles, shackle bolts and the frame area above the axles as well. My guess is this is a fatigue type failure due to the torsional forces produce by turning tightly. Check those shackle bolts because if they are frozen that will transfer a lot of force to the frame as well. Do you have a driveway that you have to turn sharp to get into? Does this trailer have spread axles? What year is the trailer? When you have this repaired have them fish plate the crossmember and not a square plate. The rule on on frame welding is never weld straight up and down on a frame. Let us know what you find and how your repair goes....
Bill Burke
Firefighter, NREMT
2020 Forest River Vibe VBT32BH
05 Chevy 2500HD 4x4 6.0
Wife W/4 dogs & 12-16 chickens
Mandog is offline   Reply With Quote
Old 11-25-2020, 09:13 PM   #8
Mr. Dan's Avatar
Originally Posted by Mandog View Post
Yep you need to get it fixed soon. I donít see any damage the other posters are thinking they see. I see your underbelly skirting is all I see. Anyway you need to look at your spring shackles, shackle bolts and the frame area above the axles as well. My guess is this is a fatigue type failure due to the torsional forces produce by turning tightly. Check those shackle bolts because if they are frozen that will transfer a lot of force to the frame as well. Do you have a driveway that you have to turn sharp to get into? Does this trailer have spread axles? What year is the trailer? When you have this repaired have them fish plate the crossmember and not a square plate. The rule on on frame welding is never weld straight up and down on a frame. Let us know what you find and how your repair goes....
So you donít see where that crossmember is torn all the way through that big round hole?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 11-26-2020, 12:14 AM   #9
I do turn sharply into my driveway, and had to a few times on the road since I got her a year ago. Sheís a 2016, with tandem axles. Didnít consider the linkage might be frozen, but the bolts do look a little corroded. The shackle nearest to the damage is a little lose and the tire near it is wearing unevenly. Just on the outside edge, like its toed in. I was about to make a post about that. Itís what got me under there to begin with, then I got more concerned with this. I have a local welder in mind, Iíll post updates. Let me know if you have any ideas on the wear, maybe a bent axle or just that loose linkage? The first tire pic is the worn one, second is just for reference
ID:	243662   Click image for larger version
ID:	243663   Click image for larger version
Old 11-26-2020, 12:55 AM   #10
After you get the frame fixed I'd check your axle alignment checked too. Are you the original owner?
wet in washington is offline   Reply With Quote
Old 11-26-2020, 09:13 AM   #11
Scrapper's Avatar
Most likely not since OP states in post above yours that it is a 2016 model and he joined the forum in October 2020.
Richard & Jill
Camping since 1989
Old 11-26-2020, 09:19 AM   #12
He says it is a 2016 that he bought a year ago, so he is not the original owner.
TxRockwood is offline   Reply With Quote
Old 11-26-2020, 10:06 AM   #13
pjones1969's Avatar
We have another brand now, but we recently had some repair work done at the factory (not FR), upon arrival both rear spring hangers had broken, Lippert, the frame manufacturer was called in for the repairs and found 2 broken crossmembers besides the obvious spring hanger failure, they added 2Ē square tubing across the frame and welded it to the existing crossmembers and gusseted it to the frame rails, Dexter also has a Recommended Cross Frame Hanger Reinforcement where channel iron is added between the spring hangers to prevent flexing. I was planning to do this once I got our trailer back but Lippert also welded gussets to each spring hanger during the repair so Iím going to inspect them and see if I need to add anything going forward.
I post this so if you do get a welder you might consider adding additional support while they are at it.
Pics here
https://heartlandowners.org/showthre...ht=#post645369
Dexter info on page 1
https://www.dexteraxle.com/docs/defa...m.pdf?sfvrsn=4
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 11-26-2020, 10:10 AM   #14
Makes me wonder if the previous owner may have had a mishap with the unit.
Old 11-26-2020, 11:06 AM   #15
Thanks for all the advice everybody, and happy thanksgiving! Not sure if it was cracked when I bought it. But the odd tire wear seems recent. I did drive it across country 7k miles. The PO did transfer what’s left of the existing warranty,, I’ll see if this repair is covered or call lippert directly.
Old 11-26-2020, 11:56 AM   #16
The cracked frame member is really a simple repair for a skilled welder, and have him thoroughly check the rest of the frame, too. Only issue I see is ensuring nothing is combustible around the welding area. As for the worn tire, it appears your axle or spindle is bent, so you do need an alignment. Your springs and shackles should be checked, too.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 11-26-2020, 12:27 PM   #17
Yes I sure do. But the other post was stating that it looked like more damage cause by something!!!
Old 11-26-2020, 03:32 PM   #18
bikendan's Avatar
The PO did transfer whatís left of the existing warranty,, Iíll see if this repair is covered or call lippert directly.
That has to be a 3rd party extended warranty and you need to read the fine print.
1. To make sure it's transferable.
2. To make sure it covers the frame.
Factory warranties are not transferable nor would be the Lippert original frame warranty.
Old 11-26-2020, 10:13 PM   #19
Whats the purpose of the hole in the cross member.
Doesn't seem like anything is passing through it.
Seems like the only thing it would do is weaken it.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 11-26-2020, 10:22 PM   #20
Commercial Member
File complaint with NHTSA of this safety problem. Include the full VIN.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Next in Mar 2021 in Perry, GA
Tireman9 is offline   Reply With Quote
crack, frame, ram
