Old 03-01-2019, 05:40 AM   #1
Cracked frames
I have been considering buying a 2007 Forest River Lexington 283TS. Only covered 22000 miles. On inspection cracked frames were found on all the slide outs . (see photos) Does anyone have experience of this. How serious is it and can they be repaired?
ID:	197855   Click image for larger version
lochness is offline   Reply With Quote
Old 03-01-2019, 06:21 AM   #2
Personally...I'd walk away.
TheWolfPaq82 is offline   Reply With Quote
Old 03-01-2019, 09:07 AM   #3
Fulltime family RVer
I’m not sure that’s cracks.. isn’t that 2 pieces butted up against each other?
Old 03-01-2019, 09:22 AM   #4
KyDan's Avatar
Iím not sure thatís cracks.. isnít that 2 pieces butted up against each other?
^^^ what he said.
It almost looks like the lower flange is bent out at the bottom. This has caused the corner joint to open up. Not sure if
this is a structural or cosmetic issue.
More photos from other angles might help.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 03-01-2019, 09:37 AM   #5
007matman's Avatar
That is not a crack.. it's a seam where the two pieces but up against each other.
One of those is bent up a bit. Might want to understand why.
007matman is offline   Reply With Quote
Old 03-01-2019, 09:47 AM   #6
Justice12t's Avatar
Maybe because the slide isn't adjusted correctly and is putting force on that bottom piece??
2016 Prime Time Crusader 294RLT
2018 RAM 2500 Laramie CTD, CC, 4x4...ect
2018 Days Camped - 15
2019 Days Camped - 34
2020 Days Camped - 30
Justice12t is offline   Reply With Quote
Old 03-01-2019, 12:50 PM   #7
Witch Doctor's Avatar
For sure that is not cracked frame, it's just a butt joint, who is to say it didn't come from the factory like that, I don't see anything structural there,
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-05-2019, 02:22 AM   #8
Retired Old Fart
dward51's Avatar
It's a point for a price reduction request, but I don't think it is structural either. Needs some serious resealing also. How does it sit with the slid in since it appears the lower edge is pushed out mostly. Like others said the root cause may just be it needs adjustment and resealing.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 03-05-2019, 06:24 AM   #9
Oaklevel's Avatar
Maybe I'm missing something but I am not seeing a cracked fame. Or a crack for that matter.
Looks pretty good for a 2007.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-05-2019, 06:29 AM   #10
Looking again at photos and it does appear that there was some torque applied to those pieces and they are bent out of shape. Question would be why/how did that happen.
crack, frame
