Old 08-23-2020, 09:21 AM   #1
mneill007
Dexter Electric Brake Wiring Sierra 33 RLIK
Looking for help for the brake wiring connection layout. Had a blowout and it pulled several wires loose from connectors. It is all located on the back driver side axle. Have 2 wires loose and not sure if I have one missing. Believe one was pulled out of the 3m scotchlock other (black)pulled from wire lock. If could provide picture, hand drawing or other would be appreciated. I don't have another trailer close by that i could look at. Thanks for any feedback
ID:	237373   Click image for larger version
mneill007 is offline   Reply With Quote
Old 08-23-2020, 09:27 AM   #2
Chuck_S's Avatar
Trailer brake wire should be Blue. Some systems also use a ground which is typically White on trailers. Both are easy to trace. Got children handy? Good bonding experience finding wires under a trailer.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-23-2020, 09:37 AM   #3
Yep need to splice them back together. The electric brakes run on 2 wires, call it supply and return. On the drivers side you'll have a spot where 3 supply wires come under one wirenut, one from the RH wheel, one from the LH wheel, one from the front of the TT. Same with the "return" wire. Just visualize supply to the brake and return from the brake.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 08-23-2020, 10:14 AM   #4
mneill007
Thanks, Don't have any kids around but do have a 2 yr old Boston that would love to help.
Old 08-23-2020, 03:22 PM   #5
mneill007
Mission accomplished. Thanks for the help and advice Chuck S and Mike134
Old 08-23-2020, 03:24 PM   #6
Your welcome
Old 08-23-2020, 03:55 PM   #7
Do yourself a huge favor and just do homeruns for each individual brake up to the front and connect them in a junction box. That is what I will be doing when the time comes. Way easier to troubleshoot too since you can separate all of them to measure resistance of each magnet.
I use something like this for all my trailers.
https://www.etrailer.com/Accessories...kaAsaAEALw_wcB
Some come with the 7 pin harness as well https://www.amazon.com/Primelux-7-Wa...8216329&sr=8-2
babock is offline   Reply With Quote
Old 08-23-2020, 05:01 PM   #8
I had a Shih Tsu that loved to help. He also saw to it my ears were clean while under the TT
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
brake wiring, dexter, electric, sierra, wiring
