Old 12-26-2018, 04:29 PM   #41
Oaklevel's Avatar
Originally Posted by babock View Post
No...your point was that Chevy brake lines rust out and no others do. I just pointed out that OEM brake lines are made by a few suppliers for all the car companies.
BTW...that's not an opinion...it's a fact.
That was not my point at all you misunderstood it. But it was an observation. I never said each manufacturer made their own lines.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 12-26-2018, 06:42 PM   #42
I was merely asking if anyone else put their TT up on blocks when in storage. I really didn't intend to start WW III. Tell ya what, let's all forget about it and have a beer. Or two....
And Happy New Year !
Chazman is offline   Reply With Quote
Old 12-26-2018, 06:53 PM   #43
And people would be shocked if they knew how much of the steel going into those brake lines was made in China Why do you think the car manufacturers are among those screaming the loudest over Chinese Steel tariff's.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-27-2018, 09:08 AM   #44
bareftn's Avatar
Originally Posted by pdqparalegal1 View Post
Grass rotting out(rusting) a steel frame. That’s a new one. Not unless you take the wheels and axles off and put frame directly on wet grass.
Have fun. 😁
Sitting on grass or dirt you have more moisture then in stone and concrete , that's way the frame rots out and if you put a blue tarp on it makes it worse all common sense
bareftn is offline   Reply With Quote
Old 12-27-2018, 11:31 AM   #45
Could you explain why vehicles don't have all these things rot when driven frequently on wet roads?
I seriously doubt that the grass has anything to do with it, more a case of how much road salt the vehicle has been subjected to.
As for covering a vehicle with a tarp, different scenario. Tarp not only traps moisture but it creates a big greenhouse trapping heat. Heat and moisture leads to mold/fungus/rot of just about anything except steel. It might rust if not painted or treated.
2004 Nissan Titan
Old 12-27-2018, 11:39 AM   #46
Prime Member
My TT is stored on gravel with nothing under the tires.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 12-27-2018, 12:56 PM   #47
bareftn's Avatar
Its easy to understand its simple when its parked on grass and dirt for days weeks at a time its called humidity and moisture, when you drive on wet roads not everything gets wet and when the roads dry out the air is moving around to dry it out. just leave a tarp board on the ground for a few weeks pick it up and you will see how wet it is unless you live in a dry area
Old 12-27-2018, 01:13 PM   #48
Ejs4029's Avatar
My RV parking at home was completed this year. I will be getting gravel for the TT to park on in the Spring...I did put some plywood under the wheels while it sits in the grass/dirt Some before and after pictures
ID:	193561   Click image for larger version
ID:	193562   Click image for larger version
ID:	193563   Click image for larger version
ID:	193564   Click image for larger version
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 12-27-2018, 01:37 PM   #49
Originally Posted by Chazman View Post
Yes, a friend of mine had his Toyota pickup bought back. I think he said he used to park it on the grass.
And my friend had his bought back (towards another Toyota) because of frame rusting and it was parked 100% on pavement.
The whole parking on grass=rust theory has been fun to read/watch!
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 12-31-2018, 08:47 PM   #50
I have a Keystone 1800RB with a single axle. I use two scissor jacks to lift the tires off of the ground and cover the tires with garbage bags. Don't know if it helps anything but I have the jacks in the trailer and it takes another 10 minutes when storing for the winter.
Hodgy is offline   Reply With Quote
Old 01-01-2019, 07:08 AM   #51
I attended a Tire Safety seminar at the Hershey RV show and the guy that gave the talk stated that concrete and asphalt can "leach" preservative chemicals out of tires and recommended using a synthetic material or wood block as a "vapor barrier" to prevent this from happening. He also stated parking on grass for extended periods was also a problem. Hope this helps.
PS: Some suggest plastic cutting boards as a cost effective solution.
YBLee is offline   Reply With Quote
Old 01-01-2019, 07:48 AM   #52
Its more important to cover the tires from the sun than taking off the weight. UV radiation is the worst thing for rubber - worse than putting weight on them.
MOODMAN is online now   Reply With Quote
Old 01-01-2019, 12:21 PM   #53
Denver To Yuma In 90 Days
It's true...even in Colorado!
I used to store my old Coachman TT up in the mountains in Woodland Park, Colorado at some friends house in their side yard on the grass (see photo below).
Almost every time when I would drive up to the camper the bottom of the trailer was damp...even at 9000+ feet above sea level!
JohnD10 is offline   Reply With Quote
Old 01-01-2019, 06:21 PM   #54
Safe thing to do
I put mine on blocks for the winter. It is a lot less stress on the sidewall. Yes, flat spots will likely round out but sitting without movement that long can be doing unseen internal damage, not to mention the UV and other environmental deterioration if stored outside.
Thearcher01 is offline   Reply With Quote
Old 01-02-2019, 02:25 PM   #55
Just finishing my last trip until spring and will be putting my trailer up on Trailerlegs
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Super easy to use and will make my bearing checks in the spring simple.
wylie31 is offline   Reply With Quote
Old 01-02-2019, 02:54 PM   #56
Great idea
WOW! Great idea, but a bit pricey.
Old 01-02-2019, 03:11 PM   #57
Never put mine on blocks, have had TT's since 1984. Always put tires 5 lbs. over max and in the spring they are always dead on when I get it ready for season. Stabs sit on two 2x10's screwed together...all 4, to handle any snow load that winter decides to drop on us. I drop the nose to assist in run off when weather warms and any snow melts.
TheWolfPaq82 is offline   Reply With Quote
storage
