F53 lube - Zerk #9
When lubing the steering on my 2016 F53 chassis, I applied grease to all 9 points in the attached image.
#9 took a LOT of grease, but never indicated full. I stopped pumping after about half a tube of grease. Something isn't right.
#9 had a rubber cap over the zerk (yep, there is a zerk, not a plug).
So, do I just keep pumping or what? Is the diagram misleading and I should not have put grease in the box? Or maybe I just messed up big time and the diagram is incorrect. Maybe the gear box should have had hydraulic fluid?
Totally confused after following the lube diagram.
McCormickJim
2017 GT 31L5
