Well, I just received a reply from Forest River, see text below. I don't think I want to pay $600 to replace my steps! but this could be the part number for the steps you need, see below. Good luck!
I have got with the plant about your step question and here is what I was given as follows.
He told me that you can use the frame of the door that is installed currently. But you would need to remove the hinges.
The door / step that I will be quoting you below would then get bolted to the frame. Then you also will need to drill
2 holes at the top of the door frame for the cover plate.
Here would we the 3 parts you will need to switch to the only option for another step for your unit
Part # F100088465 – entrance step – PFL – MOR/RYDE double step w/ 5/8” plastic step shim – 24”
Cost $ 425.70 each
Part # F100088467 – entrance step part – PFL shim for entrance step – plastic – 5/8”
Cost $ 13.82 each
Part # F100088466 – entrance step part – PFL – cover plate
Cost $ 148.50 each
2018 Flagstaff HW27ks
2019 Toyota Tundra
