While attempting to repair a stupid mistake I made (bent stabilizer jack), I noticed a nut and lick washer was loose on a bolt apparently connecting the camper sidewall to the frame. Since there is a lock washer between the nut and the frame, I assumed it should be tight. I checked along the underside edge of my camper and found about eight bolts. Two or three were tight and the rest loose so I tightened them.
I assume they worked their way loose over with the frame twisting during normal use over the past dozen years. I just hope that by tightening them I don’t pull the heads through the wood wall framing when the twisting happens again.
2007 or 08 (I forget which) Salem Lite 21FBLE I’ve had since new.
They will most likely come loose again, put some locktite on there and don’t worry about it again. That’s what we did the second time it happened to us
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
