Old 01-29-2023, 01:10 PM   #1
Falcon900Guy's Avatar
Georgetown XL 360 tires
I've posted about this before but different problem.
Not all that familiar with MH tires. My sticker I the MH calls for 255/80R22.5 tires with max cold temp of 100psi.
The tires that the dealer put on are a little different but not are exactly what it means, handling, speed indications etc.
The tires that are on the M now are:
Advanta AV2000S
275/70R22.5
Made in Thailand
Max Load Single 6940LBS at 130PSI
Max Load Dual 6395LBS at 130PSI.
GAWR front is 9000LBS
GAWR rear is 15500
Sidewall 1 Ply steel
Tread 4 plies steel.
The dealer put 100 psi in all tires. Seems a little low with a 130 max cold.
Seems that the load rating is well over what is the max for the GAWR.
Any comments as to pressure I should run?
I plan on going and having it weighted and get a true axle weight and total weight but until then???
Thanks in advance!
Falcon900Guy is offline   Reply With Quote
georgetown, tire, tires, tow
