Old 06-20-2021, 02:25 PM   #1
Holes in frame flange - would you be concerned?
So it looks like the stabilizing jacks on my trailer were replaced, and to add the new ones, they drilled some new holes, leaving excess empty holes in the bottom flange of the I-beam. I'm assuming extra holes aren't good, but are they a concern? There's 2-3 extra empty holes on each corner, some 1/4" some 3/8.
Should I see if a welder can fix this? Or is it really not a concern?
https://imgur.com/a/S0qUKj6
Thanks!
Offspring22 is offline   Reply With Quote
Old 06-20-2021, 04:32 PM   #2
Cousins
Me personally, the tiny holes wouldn’t bother me. If they bother you, have they filled. Welding on the frame may be as bad as the holes, due to the heat.
2015 Forest River Cherokee Grey Wolf Limited
2011 F150 Supercrew Ecoboost Lariat 4WD
Eddie and Catherine is offline   Reply With Quote
Old 06-20-2021, 07:13 PM   #3
prime and paint
Thomas ho is online now   Reply With Quote
Old 06-20-2021, 07:18 PM   #4
Holes at the ends of a frame rail are rather inconsequential. Very little weight out of the total is carried there. Also, the bottom frame flange is in "compression" while the top flange is in "tension" while carrying the load. Holes are less problematic on the bottom.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-20-2021, 07:32 PM   #5
Originally Posted by Thomas ho View Post
prime and paint
Yep.
2020 Coachmen Mirada Select 37RB
2020 Ford Ranger
EZGo Freedom TXT Golf cart
DougW is offline   Reply With Quote
Old 06-21-2021, 01:00 PM   #6
dmctlc's Avatar
I'd at least caulk the holes to keep water out of them.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (5 y/o)
Stephanie (daughter)/Rick/Callie (13 y/o)
Great Granddaughter - Cora (1 y/o)
Phillip (son)/Charlotte (5 y/o)
dmctlc is offline   Reply With Quote
Old 06-21-2021, 02:59 PM   #7
Pathfinder75's Avatar
prime and paint
X2
2017 Montana HC 353RL added Disc Brakes, Progressive SURGE PROTECTOR.
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
PAST- 2012 Coachman Leprechaun 319DSF w/TOAD -2011 Chevrolet Equinox 4-cyl. AWD, 2008 Springdale 266RL, 2002 Outback 25FB
Pathfinder75 is offline   Reply With Quote
Old 06-22-2021, 06:30 AM   #8
DouglasReid's Avatar
Originally Posted by TitanMike View Post
.............the bottom frame flange is in "compression" while the top flange is in "tension" while carrying the load. ..............
I think that is backwards Mike, the top being pushed on is trying to get smaller, so it is in compression. The bottom, when bending downwards is trying to stretch so it is in tension.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-22-2021, 08:06 AM   #9
Correct
boogiejack75 is offline   Reply With Quote
Old 06-22-2021, 08:14 AM   #10
Chuck_S's Avatar
They're lightening holes and since the trailer now weighs less it will tow better.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-22-2021, 09:01 AM   #11
I would think it would be both, depending where on the frame. Ie, between the hitch and the wheels, the top would be compression and the bottom would be tension as both "ends" of that segment are being supported. But behind the wheels would be the opposite as the hanging end is pulling down, making the top tension, bottom compression, no? But I'm no engineer.
Old 06-22-2021, 09:09 AM   #12
Originally Posted by boogiejack75 View Post
Correct
I think you are both right
When looking at the weight on top of the frame
top could stretch and bottom could compress
When looking at the force of the jacks on the bottom of frame
bottom could stretch and top could compress
I am dizzy now and have a sick headache.
2019 Forest River Coachman Freedom Exp 248 RBS
Jeep Grand Cherokee pulls like a dream.
First trip, 10K. Delaware to Del's Restaurant at the top of Route 66 to California, back to Delaware without a hitch or glitch. Living the DREAM!
"Brain Farts sometimes go unnoticed until further Inspection " If they only had a smell.
campers302 is offline   Reply With Quote
Old 06-22-2021, 09:30 AM   #13
The holes you have circled are the result of sloppy work. The bolts have been removed at some point. Take a caulk gun and force a sealer into those holes to prevent moisture penetration. The holes in the metal plates are for multiple purpose applications.
PenJoe is offline   Reply With Quote
frame, ram
