Old 11-06-2020, 03:23 PM   #1
how critical I replace tires?
Picked up our new to us R-Pod 190 TT in May 2020 and have taken it on short trips (total ~400 miles). Yesterday I noticed one Castle Rock tire was falling apart (see pic). The production date is 5117 (~Dec. 20, 2017). I've read on the forum about replacing tires sooner than later, so my question is how bad is this tire problem? I do plan one more 200 mile trip next week before winterization. Thanks in advance.
Name:	Castle Rock tire.jpg
ID:	242594   Click image for larger version
TNCVOL is offline   Reply With Quote
Old 11-06-2020, 03:30 PM   #2
BigH's Avatar
I'd be double checking the trailer....it looks like that tire is hitting something on the trailer.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 11-06-2020, 03:39 PM   #3
Thanks BigH. Actually took the fender off yesterday for a minor repair and there is nothing making contact with the tire and the R-Pod has the tires external of the TV frame so I don't think something is making contact with the tire. Maybe I ran over something in the past and drug it for a while, damaging the tire before it fell away?..??
Old 11-06-2020, 03:46 PM   #4
BigH's Avatar
Hmm...It looks like something stationary was making contact with the tire but who knows?
Anyway, I replaced the Castle pops after a couple pulls with Goodyear Endurance. I slept better after doing so.
18 Vengeance 28V
Old 11-06-2020, 03:51 PM   #5
Probably a good idea to replace the tires.
Replacing tires is safer and less likely to have a blowout.
I had 2017 castlerocks with 20,000 miles on them (lucky I guess) when I blew the 1st tire. No damage to trailer. Thought I should get new tires.
Then blew the 2nd tire with around $800 damage. Had to get tires. plus repair the wheel skirt. ��*♂️
Hillbillyduck is offline   Reply With Quote
Old 11-06-2020, 03:53 PM   #6
Castle Rock Tires
Our RPod 189 had a clearance light on the top of the fender...bolted to the fender. Does yours have that light...run your hand under the fender. Whatever...you need to get rid of the Castle Rock tires as soon as possible....we switched to the Goodyear Endurance(Tire Rack.com) . It totally changed towing the RPod...no bouncing...trailed straight...no sway. On a 2000 mile trip we picked up about 1.5 MPG.
Mbear12 is offline   Reply With Quote
Old 11-06-2020, 03:54 PM   #7
Wear pattern is more a classic alignment issue. I'd have that checked before installing a new tire.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 11-06-2020, 04:02 PM   #8
Lins's Avatar
TitanMike has a good point. How does the whole tread look?
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 11-06-2020, 04:21 PM   #9
BigH's Avatar
Yes a wear pattern can show classic alignment issues but what wear pattern do you see? The center tread block has a gouge line out of it and you can't see the full edge of either side of the tire?
18 Vengeance 28V
Old 11-06-2020, 05:40 PM   #10
Only looking at a picture so a lot of detail is left out. I see a "wedge" pattern on tread elements with a flap forming on what I believe to be the trailing edge.
Whan i look closely at the picture I do see a line but don't see it as an actual gouge but more like rubbed rubber from parts of the tread element. Looking at the side view, again based solely on the picture, I see a tire that has been rolling on one edge. I'd like to see pics of the full tread face and pics of the tire on the other side.
I spent my career looking at tires chewed up by alignment issues and some things kind of stand out. Of course a mere picture kind of limits the REAL picture.
2004 Nissan Titan
Old 11-06-2020, 06:03 PM   #11
PhD, Common Sense
So, they put a 3-year old tire on a new TT???
Between that and the visible damage, yes replace the tires. Id call FR and ask about the practice of putting old tires on a new TT. Tires age, even if they are not in use. They should pay part of the cost of replacing the tires.
eye95 is offline   Reply With Quote
Old 11-07-2020, 04:41 AM   #12
BigH's Avatar
I think you're slipping Mike...The angle the photo was taken for the side view doesn't show tread that makes contact with the road. You can just start to make out the side of the tread block in the upper left corner.
Hey TNCVOL show us a photo of the entire tread surface please. (I'll eat crow in the shadow of the expert if necessary)
18 Vengeance 28V
Old 11-07-2020, 09:26 AM   #13
To me - not a tire expert - that is an unusual wear pattern, likely not caused by an internal defect in the tire. I suspect misalignment, but again I'm not an expert.
In any case, the cause of the unusual wear needs to be determined and corrected BEFORE you replace the tires (which I agree you should do). Otherwise, the cause will ruin the next set of tires, too.
just my thoughts
Fred W
2019 Flagstaff T21TBHW A-frame
Old 11-07-2020, 12:19 PM   #14
I'll guess you have a 95% chance that at least one of the three year old Castlerocks will blow out on your next trip, and you'll be in the worst location to change a tire. Replace with GY Endurance if they have them in your size.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 11-07-2020, 12:27 PM   #15
rsdata's Avatar
the only thing between you and the rough side of the road is your tires... they deserve the best attention you can give them... did you ever have a good day at the side of the road changing a tire?
I saw you say this...
so I am thinking this is on a used trailer.
Carlisle is another good brand if you cannot find GY Endurance as many sizes in GY are backordered...
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 11-07-2020, 02:09 PM   #16
Maxxis tires are very well regarded on this forum as well. I upgraded to maxxis tires this year after a blowout and they have been smoother I am very happy with them
Jeff from Burlington Ont is offline   Reply With Quote
Old 11-07-2020, 02:17 PM   #17
I saw something that looked very close to this on one of my tires a few years ago. On mine that separation went almost all the way around the tire. It turned out to be a steel belt that was coming apart, according to the shop. My thought was the steel belt was not installed correctly. Yes it was an over seas tire but can't remember the brand. Those tires are over 3 years old, if they show ANY other signs of wear or cracking they would be gone before our next trip.
Just my $.02
Chuck324 is offline   Reply With Quote
Old 11-07-2020, 02:30 PM   #18
10 miles or 200 miles, if you are pulling your TT at highway speeds, be aware of the possible damage. There is not a tire place on the earth that will tell you "it looks OK for the drive", it is a personal choice.
bzac1954 is online now   Reply With Quote
Old 11-07-2020, 02:52 PM   #19
Whether that tire came new on that TT or from another one, with that kind of damage, I'd replace it, or the pair. For that age tire on a trailer, maybe it came that way but I'd bet someone saw it on theirs and wanted a new tire, which came off your trailer on the dealer's lot. Or maybe that contributed to why they sold it in the first place. Too many 'don't know for sure' issues to take a chance IMO.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 11-07-2020, 04:16 PM   #20
Great feedback, thanks. A few more details... 1) TT is a 2019 R-Pod so we are 2nd owners and that would explain 3 y.o. tires; 2) recently noticed the fender was pulled away from the TT frame and I assumed that a neighbor kid stepped on the fender and pulled it away (see post-repair pic); 3) my best guesstimate now is that I drove over something that got wedged between the fender and tire, dug out the tread until the fender pulled away from the frame and released the object. As requested a few more pics of the left tire (right side is fine w/o unusual wear patterns). Thx for the tips. Shopping now on Walmart's Black Friday sale for tires.
Name:	fender repair (2).jpg
ID:	242652   Click image for larger version
Name:	fender repair.jpg
ID:	242653   Click image for larger version
Name:	Castle Rock tire1.jpg
ID:	242654   Click image for larger version
Name:	Castle Rock tire 3.jpg
tire, tires
« Tire Wear | - »
