Originally Posted by Bama Rambler
My suggestion is to pull a hub or two and check them for grease on the brake shoes.
If that looks good then go through the wiring making sure the connections are good and tight. Including the ones in the junction box near the front.
Not just check wires but it would be a good idea to see if the magnets are actually drawing current and working as they should.
Many references made frequently to the need for a multi-meter. Even better, a multi-meter with a clamp type DC ammeter.
Amazon has several choices for relatively low prices. I like the "Tacklife" model.
It's one thing to check the wires to see if they are delivering "Voltage" to the brakes but another to check to see if the magnets are actually drawing current. Many will merely disconnect one brake wire at the backing plate and check resistance. I think the proper resistance for a good magnet is 3-4 ohms. If resistance is significantly higher or even infinite, bad magnet.
With an ammeter, pull the breakaway switch "pin" and check current draw. Four wheel brakes should draw somewhere around 12-14 amps total with each magnet drawing 1/4 of that. Only half the above numbers if just single axle with two brakes.
In short, Voltage being present doesn't do anything until current flows through the magnet.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
