Originally Posted by Viperxs10
I have a 2013 Surveyor Select 305V. What size and type hub is appropriate for this trailer? I’m not certain of the axles other than two axle, torsion type. It’s a six bolt.
Had a wheel come off on the road and damaged the studs. Anyone know where I can get the specs for the axle so that can replace the hub and bearings?
Thanks.
If you have the hub off you can take it to an automotive machine shop and have new stud(s) pressed in.
Some repair shops, even tire shops, will be able to do it too. Studs are always getting damaged or broken. Only special attention needed over a regular stud replacement is to make sure head is below surface of magnet contact area.
Usually quicker and cheaper than ordering a new drum/hub and the new one won't fit your brake shoes so another break in will be needed. If wheel came loose bearings shouldn't be damaged but you'x have them off anyway so just inspect.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
