Old 11-16-2020, 05:50 PM   #1
I知 confused !
Buying a new travel trailer wildwood 2021 27rk - I have a concern - the trailer almost weighs 7000Lbs however I was looking at the sticker along the side - and how does the axel weight make sense? 3500 per axel wouldn稚 that be 7000- no water , no tanks , no cargo . Please clarify for me if you can RenderedImage.jpeg
tbeefitz is offline   Reply With Quote
Old 11-16-2020, 06:00 PM   #2
Flybob's Avatar
The other weight distribution point is the hitch. Usually 12-13% of the gross weight.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-16-2020, 06:06 PM   #3
So I’m not sure I understand ? Does that mean the axels are fine ? I was starting to think they gave wrong ones installed ! Thank you for your quick reply!
Old 11-16-2020, 06:18 PM   #4
Oaklevel's Avatar
It does seem off did you look at the stickers on the axles to determine the 3500?
3500 x 2 = 7000 plus 700 on the tongue should be max
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-16-2020, 06:20 PM   #5
D W
D W's Avatar
Are you saying that the GAWR for each axle is 3500 lbs. ?
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-16-2020, 06:30 PM   #6
Engineering statics 301.
The ups equal the downs.
#7000 on the wheels, #1000 on the hitch thus the package can weigh #8000 or so. Somewhere on a sticker it will give you the trailer weight. The literature has the empty tongue weight.
If you load it really goofy the axels will not explode but, the trailer will sway. Tires might explode.
Everyone starts out with a bunch of weight up front with the batteries and propane.
tomkatb is offline   Reply With Quote
Old 11-16-2020, 06:56 PM   #7
D W
D W's Avatar
Originally Posted by tbeefitz View Post
So I知 not sure I understand ? Does that mean the axels are fine ? I was starting to think they gave wrong ones installed ! Thank you for your quick reply!
No, something is amiss here. A WDH has nothing to do with a TT's UVW, GVWR or GAWR. Either the sticker is wrong or they installed 3500 lb axles on it. I would physically check the axles. Should have a tag on the axle tube with PN and rating. My Salem 27RKSS is a fraternal twin of your Wildwood. It weighs in at 6800 lbs. It came equipped with 5200 lb. axles. If it does indeed have 3500 lb axles, I wouldn't buy it.
2016 Salem 27RKSS
Old 11-16-2020, 07:44 PM   #8
Chuck_S's Avatar
What D.W. just said.
You have a right to be confused.
The published data shows 7058 pounds empty plus a cargo capacity of 2452 for a total of 9506 pounds. A pair of 3000 pound axles ain't gonna support that.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 11-16-2020, 07:47 PM   #9
Retired JSO's Avatar
I知 confused !
Should be 5200 axles. UVW 7058. CCC 2452 tongue weight 710. Right off the spec sheet.
Retired JSO is offline   Reply With Quote
Old 11-16-2020, 09:27 PM   #10
I wish I knew how to post a picture here ! Lol the sticker says 3500 front . 3500 rear.
The axel underneath also says 3500 capacity.
Old 11-16-2020, 09:32 PM   #11
The dry weight is 3101kg
GVWR 3608
Old 11-16-2020, 10:10 PM   #12
If it does indeed have 3500 lb axles, I wouldn't buy it.[/QUOTE]
2X
2205S Rockwood
F 150 Lariat 3.5 Ecoboost Fx4 Max Tow
Equalizer WDH
flyflotrtim is offline   Reply With Quote
Old 11-16-2020, 11:11 PM   #13
GVWR 3608
Now I知 confused? Is it Kg or Lb?
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 11-17-2020, 01:34 AM   #14
Just as confused as you
Scrapper's Avatar
Maybe this will help. My TT has a GVWR of 8903 lbs, my two axles have a GAWR of 4000 lbs each.
Is the axles weight rating too light?
No, because the scaled tongue weight with one rv/marine battery and two 30# lp tanks with nothing else in the trailer is 1109 lbs.
8903# - 1109# = 7794#
Never use the dry weights in your calculations. They are fictional. Always start with the GVWR, figure 10 to 15% for the tongue weight on a travel trailer and 20 to 25% pin weight for a fifth wheel. Remember, hitch weight, whether WDH or 5th wheel is always added to the tow vehicle.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Scrapper is online now   Reply With Quote
Old 11-17-2020, 05:44 AM   #15
Dalford- that makes both of us - )
3500 lb axels x 2
- 710lb hitch
Dry 3106 kg
GVWR 3608 kg
Old 11-17-2020, 05:46 AM   #16
Old 11-17-2020, 07:54 AM   #17
i cannot quite make out the sticker.
If the 7955lb is the max trailer weight, loaded:
2 X 3500 = 7000lb. the other 955lb is expected to be carried by the hitch (a 15% allowance would be closer to 1200lb).
While it is entirely possible the wrong axles were installed, it seems like they are simply following their norm of giving just enough capability. This has been commented on profusely in this forum.
While I was initially ecstatic to find our Roo had more than enough capability in the TIRE loading, the axles 2 X 3000 are under the max trailer weight (~6200), putting the remainder on the hitch.
2016 Roo 21SS, 2016 F150
2015 Rockwood 2514G (pup), 2015 Fd Expl,
2003 Coleman Utah (pup), 2007 Fd Expl
Underthedog is offline   Reply With Quote
Old 11-17-2020, 10:37 AM   #18
D W
D W's Avatar
Exactly! This rig is handicapped from the get go with 3500 lb axles w/ 10" brakes, and ST205/75R15D tires. Additionally. this is a rear kitchen model with cabinet, pantry and dinette storage. None of this weight rearward of the C/G will be transferred. Entire configuration is marginal at best.
2016 Salem 27RKSS
Old 11-17-2020, 11:02 AM   #19
Lins's Avatar
It would be nice to know what your GVWR is. You uploaded low quality pictures. And how do you know it weighs 7k? I can't find a 2021 RK if I Google it, but I can find an RK-L which says the empty weight is 6156 lbs. Yes they can add weight before you get them. The GVWR of an RK-L is 7627. That gives you 1471 lbs of payload which is pretty standard for lightweight TT's. Am I missing something?
Our 2701SS has 3k axles and GVWR is 6660 if I remember correctly and when scaled fully loaded we're good to go.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 11-17-2020, 11:45 AM   #20
I apologize for the pic- hopefully this will be better. Click image for larger version
fuse
