Originally Posted by Rick the Rocket
You can split the race with a cold chisel.
I've used a die grinder to "score" the race before using the cold chisel.
I know a lot of people will go for the "blue flamed wrench" but the risk to surrounding parts and spindle are unnecessary.
Scoring the race with die grinder or dremel with cutoff wheel will both weaken the race and also provides a place that keeps chisel from skating on the hardened surface.
Only have to stretch the metal a little to loosen it.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
