Old 04-04-2019, 09:24 PM   #1
Is it ok for warm tires to exceed recomended max air pressure
My E Pro 19FD has 14 inch Castlerock tires. I installed a tire pressure monitoring system so now know what pressure and temp is as I roll down the road. I got my trailer our of storage today to prepare for a trip and found the tires were around 55 psi...sitting on cold concrete floor and Indiana temperature now around 50-60 during the day. So I filed the tires up to 60psi...realizing that they would increase psi when warmed up. Tires got up to 68psi during the 2 hour trip traveling at max 55-60 mph most of trip. Temp on tires got up to high 50's to 60's. Outside air temp got up to about 65, so not a hot day. Should I let some air out so when cold they are around 58 and when warm get up to around 65. Do I let air out as weather warms up...….and try to keep pressure so max out around the rated 65 psi when warm. I was surprised how much difference there I between cold and warm air pressure.
Bottom line.....do you want to let air out so tires don't exceed 65 psi. Or is 68 psi ok when warm?
joindy is offline   Reply With Quote
Old 04-04-2019, 10:48 PM   #2
BriaBeck's Avatar
Good question!
Good question!
The pressure on the tire sidewall is the COLD inflation pressure. It is NORMAL and Expected that the pressure will rise as the tire warms. The tires are designed for this. Do not lower the cold pressure to accommodate the pressure rise from temperature. Doing so will risk operating the tire at too low pressure for the load being carried and could cause damage to the tire.
Brian & Becky
2018 Avenger ATI 27RBS
BriaBeck is offline   Reply With Quote
Old 04-04-2019, 11:01 PM   #3
Just as confused as you
Scrapper's Avatar
Do you let the excess air out of your car or truck tires when they get warm from driving? Not likely. Just like your car or truck tires, your trailer tires are made to tolerate the extra pressure as they warm up from driving. That's why the writing on tire sidewall states the cold inflation pressure is xx psi.
Richard & Jill
Old 04-09-2019, 08:58 AM   #4
Dodge Guy's Avatar
Yep, “cold inflation pressure” letting air out will make them run hotter and won’t have the carrying ability depending on what the trailer weighs.
On my old trailer I would run the “E” rated 80 psi tires at 70psi.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-09-2019, 09:01 AM   #5
Flybob's Avatar
Yes. Both the temp and the pressure will increase as you drive. You will also notice that the temp and pressure will usually be higher on the sunny side of the RV. This is normal.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
pressure, tire, tires
