Old 02-25-2019, 05:54 PM   #1
Jack & crank
ON A NEW CEDAR CREEK 38EL CHAMPAGNE,where would the manufacture put the jack,lug wrench and the crank to lower the tire.Im all buttoned up for the winter and don't want to re open it up too look for the items myself.
BOB3288 is offline   Reply With Quote
Old 02-25-2019, 06:13 PM   #2
no jacks or lug wrenches with trailers . tool for spare s/b the same as for the stabilizer jacks . hope this helps
MR.M is offline   Reply With Quote
Old 02-26-2019, 04:55 PM   #3
SilhouettePenny's Avatar
Sorry, no jack or lug wrench...crank for the spare tire is in the front basement storage area. Do not put a 4 way lug wrench on your wheel lug nuts, get a dedicated thin wall socket and breaker bar.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 02-26-2019, 09:06 PM   #4
rracer5's Avatar
But, use a torque wrench when you put the lugs back on. Actually, you should carry one to check the torque for the first 150 miles or so and any other time a tire/wheel is removed and reinstalled.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-26-2019, 10:51 PM   #5
BriaBeck's Avatar
Why?
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
Old 02-27-2019, 07:36 AM   #6
Originally Posted by BriaBeck View Post
Why?
The manufacturer ships most rigs with a cheap thin metal cap pressed onto a standard automotive lug nut. One twist of the nut with a 4 way that does not completely encircle the lug nut and you have a damaged but almost impossible lug nut to remove and reinstall. Additionally, a lot of wheel manufacturers aluminum design won't allow a 4 way to seat properly, hence the thin wall socket suggestion. TSC or any auto parts store can get you a 24" breaker bar and socket for the new lug nuts, which will be a different size than the cheap original. First upgrade on a new camper = solid chrome lug nuts from Amazon. While you're at the parts place get yourself a 30mm socket for the water heater drain also, and some Teflon tape.
2019.5 Hathaway
Old 02-27-2019, 12:26 PM   #7
rracer5's Avatar
4 ways are shallow & grab just the end of the nut.
Make that a deep well socket preferably a 6 sided one!
2014 Sanibel 3250
Old 02-27-2019, 03:19 PM   #8
BriaBeck's Avatar
Ahh, got ya. Makes sense if you got all that blingy stuff.
No danger of that happening with me... I've just got your regular old school nuttin' fancy plane jane good ol' reliable no frills all bang no flash getter' dun lug nutz.
4-way will continue to work just fine.
Brian & Becky
Champion 3500
Old 03-02-2019, 07:32 PM   #9
I purchased one of these jacks for my TT..it combines a bottle jack with the safety stand.
https://www.amazon.com/Alltrade-6409...s%2C230&sr=8-4
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-03-2019, 09:45 AM   #10
I donít carry a bottle jack for the camper, if I was to have a flat on my Cedar Creek I would use the Level-up to jack the camper up
spock123 is offline   Reply With Quote
