Old 05-28-2023, 06:11 PM   #1
Leaf Spring Replacement Help
Hey Everyone,
Have a couple of questions regarding parts when replacing the leaf springs.
1. Should you replace the ubolt mounts or is it ok to reuse the existing? Here is the link to the springs I was going to install.
https://www.etrailer.com/p-e78SR.html
2. Should you replace the shackles as well?
Not sure if I need to order all of these parts or just the leaf springs.
This is on a 2022 Wolk Pup 16PF with a 5100# axle.
Thanks!
Tim
2022 - Wolf Pup 16PF - "Phillip"
2021 - Ford Explorer ST
tjmiller is offline   Reply With Quote
Old 05-28-2023, 08:07 PM   #2
A 2022
Originally Posted by tjmiller View Post
Hey Everyone,
This is on a 2022 Wolf Pup 16PF with a 5100# axle.
Thanks!
Tim
It's a 2022. How worn do the parts look? If you only have a few thousand miles on them, there should be no need to replace. Be sure to grease everything when you reassemble.
Larry
Larry-NC is offline   Reply With Quote
Old 05-28-2023, 08:10 PM   #3
onetonford's Avatar
I myself would use what I have as long as they are not damaged or worn.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 05-28-2023, 09:31 PM   #4
Photos
So today I went under to install the Sumosprings, the left side seemed OK. The gap between the frame and the bracket was about 3.75in. Which did not require me to use any spacers. But the right side distance was at 3.25 from the spring to the frame and the leaf spring strap was no longer on 3 leafs, only two. It appears much flatter that the left. This surprised me because the slide out is on the left and I thought the weight of it would have flattened it out more.
The strap looks in place but it is not. I can easily slide it to the left. It is barely touching the 3rd strap.
BTW it is out of warranty and I feel better getting higher quality parts myself as opposed to dealing with the manufacturer.
Here are some pics I captured.
ID:	287802   Click image for larger version
ID:	287803   Click image for larger version
ID:	287804   Click image for larger version
Old 06-05-2023, 02:01 PM   #5
The main leaf on one of my springs failed entirely. Turns out that the main leaf had a MAJOR flaw in the metal right at the point where the largest secondary leaf ended. Snapped off cleanly.
Since you are concerned about sag on one side, take a very close look at each leaf...especially at the point where smaller leaves end...and see if you notice an issue.
Why bother? Warranty. Many suspensions are warranted for 5 years. Dexter picked up the entire tab for my repair...although it took a long time and lots of "Karen"-like calls and emails. If you see a real flaw, they may pay for the replacement...including labor.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is online now   Reply With Quote
Old 06-05-2023, 03:08 PM   #6
Your hardware looks good and certainly could be reused.
BTW... that S/Steel strap is meant to hold the spring pack together during assembly.
This flimsy strap often gets confused for a rebound strap that keeps the spring pack together when a wheel drops during suspension travel. They are much more substantial and usually riveted to one of the leafs. Yours does nothing for rebound but it may have some ID numbers on it.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=86
Old 06-05-2023, 03:22 PM   #7
I would buy a shackle bolt kit for this job. Adds new bushings and wet bolts for the springs.
Also I might replace the equalizer between the shackles if you have a primitive one.
$3-400 more in parts. No extra labor.
We had structural metal added between the spring hangers. Adds stability to the rv frame.
tomkatb is offline   Reply With Quote
Old 06-05-2023, 04:15 PM   #8
clr
I would recommend also changing the shackle to a HD type. Also I would recommend that you also change the bolts that attach the sprang to the shackle on both ends. I would go with what are called wet bolts so that you can grease them. Once you get into this you do not want to stop and wait on parts. You will not be able to tell if the bolts have ovaled out the shackle until you take it apart.
The u bolts look fine to me.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
replacement
