Old 10-06-2018, 04:34 PM   #1
Lift kit needed?
We just got a Vengeance 394 and am pulling it with a Ford F-350, the truck sets a little high and by placing some scrap wood under the tires it took about 3 to get the camper to ride level. Does this mean that I should look at getting a lift kit for the camper?? How much difference in height is too much?
Went from a Gray Wolf 29bh to the 394 so Im New with fifth wheels
Realhusker is offline   Reply With Quote
Old 10-07-2018, 06:29 AM   #2
No-Fish's Avatar
Top of the Morning to you, Are you running a f350 with duals or single rear wheel? I pull a 38ft jayco 5th wheel, with 16inch truck tires, I had the trailer axles adjusted ,for more height. if that hasn't worked for you , There is a kit for the front coil spring, that will bring the front of the truck up about 2 to 3 inches.
No-Fish is offline   Reply With Quote
lift
