04-06-2019, 05:57 PM
Lions Head Aluminum Wheel Valve Stem Size
We just purchased a 2019 R-Pod RP-180 with the Lions Head "Cheetah" style aluminum wheels. See Here
I plan on using a TST 507 TPMS on the R-Pod wheels and need to change the stock rubber valve stems to metal valve stems. The one thing I can't find anywhere on line is what size valve stem does Lions Head use in their aluminum wheels. Is it the standard .453 inch valve stem?
Thanks!
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
04-06-2019, 08:15 PM
Yes, it's the 0.453.However when using a clamp in valve stem, on some of those aluminum wheels you made need a more specialized stem because of the way the lip is made. I have several threads on this. Let me find one when I get home.
2011 Flagstaff 831 RLBSS
04-06-2019, 08:24 PM
Get stems that bolt from the inside of the rim.. outside ones may not fit properly due to the way the wheel is shaped around the valve stem opening..I ran into this issue.. luckily the tire shop I was at had the ones that bolt from the inside..
04-06-2019, 08:30 PM
Here is one thread that explains the TR-428, which would also solve the problem REL ran into without using the Enkei type valve stems he is describing.
http://www.forestriverforums.com/for...tml#post535157
http://www.forestriverforums.com/for...ml#post1456764
My problem with Enkei types is they sometimes loosen/leak and you have to dismount the tire to just tighten the nut. I run into this in the course of my business. The TR-428, allows you to tighten from the outside, and thus no need to dismount the tire again.
Either one will work.
04-07-2019, 06:59 AM
Thanks for the responses! Previously I've always ordered metal valve stem kits from DuallyValves (Borg) for our motor homes. This one was a bit more tricky since Lions Head doesn't publish the specifications on their website...
Wayne
04-07-2019, 03:53 PM
Thank you...
Wayne
04-07-2019, 04:58 PM
I also used the 17-428 and they have worked fine - see link:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2010 Toyota Tundra DC SR5 5.7l 4x4
2020 Grand Design Imagine XLS 22MLE
Andersen WDH
2018 Rockwood Mini Lite 2104s
2014 Jayco x17z Hybrid
04-07-2019, 07:25 PM
Thanks... They certainly filled in the valve stem pocket!
Wayne
04-08-2019, 09:38 PM
MCTroy
Ok, I will all the dumb question. Why change valve stems? I just ordered the TST Tpms. Does it require metal valve stems?
04-08-2019, 10:57 PM
I ran my flow thru sensors on our camper with the stock rubber stems last summer and noticed the stems would allow the sensors to lay over against the rim and caused rubbed spots. Changing out tires this year to get rid of the Castle Rocks and will be changing to metal stems.
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
04-09-2019, 04:44 AM
MCTroy
Thanks, Tonyz1. We already upgraded our tires so I will watch the stems and see how they do.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
04-09-2019, 09:27 AM
TST does not require metal valve stems but their support recommends that you use them. Even though the sensor only weighs an ounce or so the centrifugal force of the wheel spinning could potentially cause it to rub, create an air leak, or even pull the valve stem out...
Wayne
