04-04-2019, 03:27 PM
Lippert AND Dexter axles???
I have a 2018 Wolf Pack 24 toy hauler, bumper pull. We just took a trip from Wisconsin down to the Fl Keys and on the way there in southern Georgia the rear drivers side bearings went out taking out the axle. Yes, now I know not to really trust the ez lube hubs and will be doing it right from now on. Anyway, we were broke down for 2 days and finally found a place that sold Dexter axles(ours has a lippert). It has the same 5200 lb rating but was 1.5" shorter end to end, it also came with hubs and brakes. We ended up buying it and found a welding shop in town to weld on the spring perches. My question is,, will I have any problem running 2 different kinds of axles? The rest of the trip it seemed to pull fine, and I didnt notice any weird tire wear.
thanks for your input.
04-04-2019, 03:33 PM
I went out and looked at mine to see if I had an axle that was 3/4" shorter on each side. I don't think I would have an issue at all. A long as you have plenty of clearance, I don't see a problem.
I replaced all my bearings with US made Timken bearings and hand pack only. I do not use the EZ lube "feature". In theory it would be good for people that don't have mechanical ability but its not worth using it in my opinion. Read about the people that grease the entire drum brake systems after the rear grease seal leaks..
04-04-2019, 03:47 PM
Axle mounting width and spring mounting brackets are typically sized/welded so they are centered on the frame flange(s).
How did they attach the mounting perches?
Were they just different brackets to match the Dexter springs and the old Lippert brackets removed and the new installed in the same spot?
Any photos?
04-04-2019, 03:52 PM
I had the same situation happen to me this past Oct coming back from Nashville. It was the same axle and result. That brake drum had split in half also. Had to replace the rear axle and I had them replace the front axle also. Glad I did as I went from 10" brakes to 12" brakes. The new axles were 7000# and were made in Beebe, AR. Also found out that two of my spring hangers had broken away from the frame (poor welding). All is fixed and now I am a happy camper.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
04-04-2019, 05:01 PM
The new axle didn’t have any spring pads on it, but came with them to weld on to your size. The welding shop we found centered the axle and welded them on.
I bought the axle at a “big Tex” trailer dealer in Cordele, Ga. ,, if they weren’t around I’m not sure what we would have done.
I was hoping I could just run it as is now and not have to go buy another new axle and go through all that again!
I guess now I just order 2 different bearing and seal kits when I re grease.
04-04-2019, 05:35 PM
Denver To Yuma In 90 Days
Had that happen to me going through Phoenix about four years ago...
No axles to be had in town and would take a week to get one from Elkhart.
Sun City RV took the axle off and sent it to an axle shop where they cut in in half and welded another half to it so I could finish my trip and drive the 1200 miles home.
Cost me $ 1000 for that...and another $3000 when I got home to get two new upgraded axles, springs and bigger tires and wheels.
That was also when I found out just how much money I wasted on the dealership-sold extended warranty...it was worthless!
They didn't pay a dime.
04-04-2019, 05:52 PM
They are different? Surprised considering they are the same rating.
04-04-2019, 06:49 PM
Honestly I’m not sure if they are different, just figured 2 different manufacturers would use different parts.
04-04-2019, 06:52 PM
They could easily be the same. Easy to take the outer off to see if they are least the same.
04-05-2019, 01:27 PM
Dexter Axle
We heard noise coming from our axle/wheels and had a mobile rv mechanic come out. He had to repair and replace parts on all four wheels. We contacted Dexter and they reimbursed us for our costs which was $1300+. Good luck.
04-06-2019, 08:58 AM
Just FYI. In 2014 while on a trip from Texas to Alaska and back we had a wheel bearing fail and chew up a Lipert axle in Kansas. We found a Dexter at a trailer shop and with local help swapped it in a small city park. Later in the same trip between Denali and Anchorage the other Lipert repeated the trick. All had been service by our dealer just before we left home. We limped into Anchorage and found a shop that specializes in trailer suspension repairs. They replaced the bad axle with a Dexter that matched the rear in less than four hours. We never had another axle/bearing problem over the next five years. Our new Flagstaff has Dexter units and I am very pleased about that.
04-06-2019, 09:20 AM
My Avenger with Dexter axles had excessive play in the bearings in all 4 hubs... Make sure they're properly tightened.
The factory gets these axles as a finished assembly, and they just bolt them on, mount the wheels, and down the road it goes.
Dexter has a good reputation, but if they're the first ones made on Monday, or the last ones made on Friday...
Brian & Becky
2018 Avenger ATI 27RBS
04-06-2019, 09:24 AM
Or all the other ones made in between on Tuesday, Wednesday and Thursday...
04-06-2019, 09:34 AM
Good point!!
Brian & Becky
