Below is the response I received from LCI. I haven't had time to troubleshoot the issue yet but wanted to share the info I have. I will update with results later.
Thank you for reaching out to us directly at LCI concerning this issue. Are all 4 rear jacks, 2 middle and 2 rear, drifting down or is it only one side of the trailer? I would start by checking the valves on the valve block near the pump assembly. The drivers side valve will have a purple wire and the passenger side valve will have a blue wire. Use a 5/32 allen wrench and turn the center set screw counter clockwise. If it does not turn, do not force it as it will break. You are checking to see if they are open. If they are not, then issue will be with a jack, or multiple jacks are internally bypassing. The middle and rear on drivers side are plumbed together and same with the passenger side jacks. If one of the jacks is internally bypassing, it can cause the other to leak down, making you think its the one drifting but could be the opposite so you will want to do cylinder bypass tests on each leg to confirm. To do a cylinder bypass test you will remove the extend hose, closest to the frame rail and usually orange, and you will want to press and hold retract for 10 seconds on each jack. If you have any fluid that comes out of the port on the jack, the jack is internally bypassing and will need replacing. If no jacks are bypassing, replace both valves for the rear legs and the issue should go away.
I have added a couple of links below that will assist. If you have any questions while doing this, you can email back or you can contact our phone techs at 574-537-8900
https://lci-support-doc.s3.amazonaws...cd_0001749.pdf
https://lci-support-doc.s3.amazonaws...cd_0001531.pdf
