A lot of folks don't trust using the zerks because if they overfill the cavity, grease can blow by the rear seals and coat the brakes. The cavity is not filled from the factory, just the bearings are greased. Removing hubs to service the bearings also provides the opportunity to inspect the brakes, your choice.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
