Old 10-21-2020, 04:27 PM   #1
Lug nut torque
Have a 2017 Columbus F377MB fifth wheel. ST235/85R/16 tires with 8 lugs.
Could someone tell me the torque for these wheels? thanks.
mike grist is offline   Reply With Quote
Old 10-21-2020, 04:51 PM   #2
The lug torque is based on fastener thread size! Is your lugs 1/2" or 9/16? Youroo!!
Old 10-22-2020, 05:46 AM   #3
Not really sure of thread size, but I would guess 9/16
Old 10-22-2020, 05:54 AM   #4
Then you need to remove one and measure! I guess? Youroo!!
Old 10-22-2020, 09:55 AM   #5
Courtesy of Tire Rack:
Hardware Bolt or Stud Size Typical Torque Range in Ft/Lbs Minimum Number of Turns of Hardware Engagement
12 x 1.5 mm 70 - 80 6.5
12 x 1.25 mm 70 - 80 8
14 x 1.5 mm 85 - 90 7.5
14 x 1.25 mm 85 - 90 9
7/16 in. 70 - 80 9
1/2 in. 75 - 85 8
9/16 in. 135 - 145 8
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-22-2020, 02:15 PM   #6
Thanks and I will measure one today and go by the chart.
Old 10-23-2020, 11:02 AM   #7
ebemis's Avatar
MAYBE.... is there a sticker on your trailer above the wheel wells like mine that lists the torque right on it?
Ed & Chris, Empty Nesters (missing Josh & Jaclyn)
along with Blue & Tessa, Cat Explorers!
2020 Rockwood Roo 235s
2019 F-250 Diesel 4x4 Super Duty
ebemis is offline   Reply With Quote
