I have been camping almost 20 years and rarely had a tire issue. I wear my tires out from use or an occasional nail. Recently we installed cap style tpms sensors on rubber valve stems. Multiply stem failures. I went to the high pressure rubber stems we still had stem failures. Also a FYI. We had tampering/vandalism to our stem while at a campground in Alabama(we will never return! 2 of my rubber valve stems were kidded and damaged. Per the pre trip check pressures were fine, a mile down the road valve stems failed completely. My tire guy told me to put metal valve stems on wheels. This will take care of the two problems: rubber failure and vandals.
Safe Travels
Note: it does NOT take much time to destroy a new tire along with the safety issues along the road changing to a spare once you fine a safe place to change it. Carry spare stems!
