Originally Posted by KIPKERS
My folks have a XLR with the lci auto level system. Today when leaving the camp ground theyou would not retract. Finally was able to get them up. Now back at storage and they won't go down, when going into auto level it starts and then says low voltage. Battery monitor shows 13 volts.... any ideas
I have the LCI Ground Control 3.0 and just this week ran into what I think was your same problem. I have a AGM battery that I bought this year and the last time I was at the storage lot a week ago, the panel showed fully charged. Yet when I went to get the trailer for the trip I'm on, the LCI was showing error and wouldn't raise the legs. I checked the panel and it said Weak battery.
The solution was a 2 parts. First, luckily I have a little 40watt solar that's not much good for anything but battery tending. I hooked it up and waited about 15 minutes and apparently that was enough to get the LCI to raise the front legs. Although it wasn't smooth. I had to press the Front button and the legs would go up a smidgen. Then press again, and again and finally they made it up and I hooked and left on the trip.
By the time we got to our destination 8 hours later, the battery was fully charged and I expected the LCI to work as normal. It was better than before but still not normal. I could raise and lower the front legs but it kept beeping showing an error on the right rear jack.
I went ahead and unhooked the trailer then I followed these LCI instructions to clear the errors.
1. Manually extend so that each leg is down at least 6 inches.
2. Press and hold the Retract button until you see 'Auto Retract All'
3. Let the Auto Retract complete it's cycle, this could take 3 or 4 minutes so be patient.
4. After that completes, press Auto Level and the trailer will complete and errors should be cleared.
I still don't know why my battery was down, but I'll with that separately.
