09-08-2024, 07:48 AM
NEED HELP, stuck at a rest area
TT is my signature. The passenger side of the trailer is less then 2 inches from rubbing on the wheel well. I find nothing broken, axle looks ok and leaf springs also. I noticed it yesterday but thought I had to much on that side. So i removed things on the side placed them on the driver's side. Parked for the night and it's still way to low. I have 6 inches on the driver's side.
The lone picture with the huge gap is the driver's side. There is nothing on the passenger side other than an empty fridge, stove and microwave.
09-08-2024, 08:23 AM
tires still look good
I would just go slow and stay off real bumpy roads
keep close eye on tire wear until you can have everything inspected by someone that can do suspension / springs
Tarpon Springs FL
2022 Salem 24RLXL
09-08-2024, 08:27 AM
^^^^ What he said ^^^^^ Would also be helpful to know what your trailer is..............
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
09-08-2024, 08:41 AM
His profile shows ‘2024 Grand Surveyor BHXL 240.’
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 97; Booked for 2024 = 28
09-08-2024, 08:45 AM
2024 Grand Legend surveyor 240 bhxl, is not in the sign? Or did that disappear?
09-08-2024, 08:58 AM
You have a bad amazon link in your sigline. I removed it which may be your issue. Also make sure when you post, under additional options, you have the show signature box checked. If it's not, you may have it turned off in your settings.
2011 Flagstaff 831 RLBSS
Sometimes I wonder why I'm not in an asylum. Then I take a good look around at everyone and realize...Maybe I am.
09-08-2024, 08:59 AM
It is not.
Is this issue something that just happened or did you just notice it.
A 2024 model, maybe you are just returning from buying it?
It's hard for us to tell what may be going on with the frame/suspension without being there but if it is still under warranty, you need to have them look at this immediately. From the photos, it "appears" there is an added piece under the spring shackles.
You are going to have to go slow and get to a repair facility.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
09-08-2024, 09:02 AM
Sorry I saw nothing in your public profile. Still don't
1966 Mustang GT
1986 Mustang SVO
09-08-2024, 09:03 AM
X2. Good advice.
When that happened on our trailer, the leaf springs had flattened. We think that traveling over rough roads contributed to the failure. Lots of potholes we couldn't avoid hitting on the right side.
2015 Dynamax REV 24TB class C
09-08-2024, 09:33 AM
My guess.
Something with the springs.
Broken leaf. No clips.
Noticed on the level parking lot the equalizer device seems wonky.
Currently manufacturers have been cheeping out on structure. Frames falling apart. Not apparent here. Hangers seem fine.
Tires ok.
Seems between the frame and axles.
There has been a lot more spring issues than in the past.
Good advice. Go slow and park that rv where you can deal with it.
I had my spring clips replaced by a professional.
09-08-2024, 09:46 AM
Originally Posted by tomkatb
My guess.
Tires ok.
I agree. The springs on the other side seem to have a nice curve to them and the springs on the low side are flat as a pancake. Get somewhere you can replace the springs. If it were my trailer, I would replace all of them with 4 leaf spring packs. Forest River loves to use the smallest, cheapest spring packs that meet requirements, barely. Replacing springs is pretty easy. Might as well add wet bolts on the shackles while you are replacing the springs.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 10,700Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
09-08-2024, 09:48 AM
My guess.
Tires ok.
One picture is the springs on the passenger side and one is on the driver's side. Notice the difference in the curve? We are parked at the Loves campground on OK. Supposed to have someone come out about 1-2 pm today. At least we have full hook up.
09-08-2024, 11:48 AM
If I were doing this I would consider one of the $300-400. Equalizers.
This trailer is pretty heavy.
Plus wet bolts. Heavier shackles.
But, we do a lot of miles per year.
If still under warranty you could contact your dealer. However, $300 worth of springs is no big deal. You could change two to get home. $150.
09-08-2024, 12:25 PM
It appears to me, in your pictures, the leaf springs have flattened, judging from the appearance of the shackles and the pictures of the springs.
Bob
09-08-2024, 12:39 PM
You are missing a leaf spring on the low side.
09-08-2024, 01:10 PM
Nope, they are all there.
09-08-2024, 01:11 PM
Those leaf springs look flat are you sure your not missing a spring in the pack. Also not sure if it's just the picture but it looks like you may be missing a nut on one of the U bolts.
09-08-2024, 01:16 PM
Yes the passenger side is flat. But no nuts missing. Thank you for looking and the suggestion.
09-08-2024, 02:22 PM
We just had a similar situation. Confirmed at a scale we were no where near overloaded. Replaced all four leaf springs with a slightly heavier spring recommended by the axle shop. I feel the trailer performs much better now.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
09-08-2024, 03:55 PM
Not visible if you're using the mobile version of the Forum.
