05-07-2012, 08:25 AM
Nitro filled tires? Any opinions??
They tell me....don't worry, these are GREAT! Won't lose pressure, if you need a little pressure on the road put in a bit of air.
Does anyone have experience with these?
05-07-2012, 08:33 AM
While I don't have any first hand experience with this, the air we breathe daily contains about 78% nitrogen. I don't know what they charge for a 100% nitrogen fill but personally, I would take that money and put it toward a tire pressure monitoring system. JMHO.
Tom and Margaret
2014 Berkshire 390bh-60
05-07-2012, 08:37 AM
Now a "Top Member"
Yes, no, maybe. There are many threads on this. If you search, you'll find all you want and more. I will say though, they do lose pressure. I usually have to air mine up at least 5 - 10 pounds before each trip. And I use regular air from my home air compressor.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
05-07-2012, 09:03 AM
I say gimmick.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
05-07-2012, 09:26 AM
I was skeptical myself, but so far I haven’t had to add any air to the factory nitrogen filled tires yet. We’ve only had the Silverback for just over a month but we've been on three trips with the trailer. Time will tell I guess. If I have to add pressure to the tires I’ll will be adding air. Air is free, nitrogen isn’t.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
05-07-2012, 09:31 AM
It would be interesting to see a pressure rise/ temp rise difference
Between nitro and air filled tires with those of you that have tpms
systems.
any one any one one? Bueller?
05-07-2012, 10:25 AM
systems.
Maybe these are worth a read??? Tires - Nitrogen air loss study
Nitrogen vs Air In Tires - Why Nitrogen in Tires - Popular Mechanics
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
05-07-2012, 10:29 AM
Anacortesians
Based on aerospace industry research (I did it personally), nitorgen is only necessary if your RV had retractable landing gear and can do a couple of miles at 150 mph with a dragging brake.
Total waste of money. Why not fill them with hydrogen and make your rig lighter?
Frank and Eileen
No longer RVers or FR owners
05-07-2012, 10:31 AM
Just a quick thought..I heard that nitrogen has larger particles in it and that's why we don't lose air in our tires. I have had to add air in my Cedar Creek once to keep my pressure up to 105 lbs. Usually air will leek out just sitting. We've been to AZ and back to MI twice with this 5th wheel and the tires stay at 105 moving or setting on a lot. The one I had to add air to was left rear that the stem came loose for some unknown reason as we were checking tires to leave our winter site this year, I tightened it and added about 10 pounds to bring the pressure back up.. I think there is some good to nitrogen filled tires and you can just add air when needed. After all it is air...
2011 Cedar Creek 36B2 ordered with outside kitchen removed and a nice big wardrobe in it's place.
Pulled with a 2011 F-250 Super Duty 6.7 Diesel Crew Cab and 8' box with a Hensley BD-3 Trailer Saver. F R O G members.
05-07-2012, 10:48 AM
The only true way to put Nitro in is totaly evacuate the Air out of the tire,with a vacuum pump and fill with Nitro. I have never seen a tire dealer do this. I use air. Youroo!!
05-07-2012, 11:06 AM
I appreciate all the opinions, the fact is the new rig has this feature and I've had no experience with it.
05-07-2012, 11:24 AM
Hydrogen. Hindenburg. Hello?
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2021 Chevy High Country 6.6 gasoline
Hensley Arrow, best investment ever!
05-07-2012, 11:27 AM
Now a "Top Member"
Yup...mine did too. And as the pressure got low, I added regular old air. It's certainly not worth me trying to 1) find a place with that sells nitrogen; 2) hook up my camper and pull it there; and 3) pay the exhorbitant amount I've seen some places asking for it.
Air works fine for me...your results may vary.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
05-07-2012, 11:36 AM
I found no good reason to be concerned about air or nitrogen. I removed the "Nitro" decal and will use regular method to fill tires. Local Les Schwab dealer could give no good reason to use nitrogen unless maybe I was dealing with tires on a race car on a track that might generate extreme heat.
So for now, it is good ole compressed air from my own compressor.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
05-07-2012, 11:50 AM
Been using air for over 56 yrs of driving and will continue until I start pushing up daisies. See no benefit in nitrogen other than making somebody else more money which is definitely not to my advantage.
05-07-2012, 11:51 AM
Why not go for broke and use Helium?
05-07-2012, 09:36 PM
I often wondered when I seen some labels on TT that had nitrogen filled tires, where do you get the nitrogen when traveling down the road? We used to air our struts on aircraft with hp air, now they use a nit cart to fill the tires, accumulators and struts. I guess I will continue to use just plain air since I can't afford a cart plus I don't plan on no rapid altitude changes with my rig.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
05-07-2012, 10:04 PM
I wouldn't put nitro methane in my tires! One good bump and ka-blewy!!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
05-07-2012, 11:25 PM
I will let you know after the May long weekend. I put nitrogen in the trailer tires and have TPMS to put on also. I will be monitoring the new toy lots to see how much the tire pressure varies after tires warm up travelling.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
05-07-2012, 11:40 PM
IMO save your money.
There are many threads on the subject pro and con.
http://www.forestriverforums.com/for...res-13825.html
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
