under hood fuse box, number 26--30 amp is for trailer tow. Number 29, relay, says trailer tow lamps. Your owners manual should verify this. See attached picture.
If you have a meter a test light or even a test plug with lights you can check them.
The 2018 should also have a trailer menu on the dash that will test and show the trailer lighting working or throw an error.
Without a test light the fuse and relay are the first place to start. With one check the plug even if it means a different trailer or accessory to test.
