Old 03-19-2023, 03:08 PM   #1
No Brakes!
Brakes in our TT worked well from Tucson to Why, AZ. Even for a panic stop.
3 days later, after hitching up, tested the brakes on leaving camp and nothing. I tested the umbilical cable conductivity and visually inspected the wires to each wheel. No anomalies noted.
With DW squeezing the brake controller paddles my VOM could not detect a signal at the umbilical junction box.
Changed settings on the built-in brake controller this morning and retested. I could feel a VERY slight tug at 10 mph on squeezing the paddles and then a release.
Do I take it to Ford or to a trailer shop? TV is a 2020 F-150.
Robertsmusings is offline   Reply With Quote
Old 03-19-2023, 03:21 PM   #2
First thing I'd check would be the contacts both in plug and socket where Umbilical Cord is plugged in.
A quick check of the "trailer side" is to unplug Umbilical cord from truck, pull the breakaway switch cable/plug so trailer brakes are fully energized, and now try to pull the trailer. Should be either impossible or darn difficult. If not on dry pavement the wheels will most likely be locked up if all is OK.
If brakes activate fully then the problem is either in Umbilical cord, connector, or controller. Messing with those will be limited to your skills or desire.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-19-2023, 04:45 PM   #3
I did check and clean the contacts.
Thanks for suggesting pulling the breakaway pin. I'll try that next.
Traveling and Exploring wherever life leads us
2021 Flagstaff Super Lite 26FKBS
2020 Ford F-150
Houseless since June 2021
Old 03-19-2023, 05:12 PM   #4
The battery on your trailer is fully charged?
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 03-19-2023, 05:33 PM   #5
Yes.
2020 Ford F-150
Old 03-19-2023, 06:17 PM   #6
With the breakaway pin pulled, the tires rotated easily.
I will be looking for a competent trailer shop in Buckeye, AZ tomorrow.
Thank you
2020 Ford F-150
Old 03-19-2023, 06:18 PM   #7
I made a tester with an old blower motor and a 7 way round connector. Using only the trailer brake control and ground. It is a great way to visually show someone the vehicle is working.
cbty is offline   Reply With Quote
Old 03-19-2023, 07:52 PM   #8
when I lost my brakes completely like you did including the break away it was a cheap crimp connector that visually looked good had failed on the heavy blue brake wire under the trailer
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 03-19-2023, 08:38 PM   #9
Thank you
If all wheels turned freely the problem is just in the connection to battery, breakaway switch, or wire from breakaway switch to first connector where brake power branches to each side.
2004 Nissan Titan
Old 03-20-2023, 07:00 PM   #10
sonofabeacher's Avatar
Check your owners manual for your tow vehicle. There could be a fuse for trailer/tow brakes. I don't know if Ford has one but I do know Chevy does. It could be under the hood.
sonofabeacher is offline   Reply With Quote
Old 03-23-2023, 06:45 AM   #11
We had total brake failure because the brake lines were not mounted securely on the axle. Forest river said they should have been tied down with just plastic zip ties. How ridiculous is that. The hydraulic brake lines are metal and they just flop around, eventually causing a snap. Forest River of course doesn't want to pay for repairs. Accident waiting to happen.
Travelers2k is offline   Reply With Quote
Old 03-23-2023, 08:34 AM   #12
curtiscapk's Avatar
#4 fuse passenger fuse block
https://www.startmycar.com/us/ford/f...o/fusebox/2020
Love this site!
2022 Primetime Tracer 24DBS
2013 f150 2WD 5.0 OEM tow package
EQUALIZER 4 WDH
curtiscapk is online now   Reply With Quote
Old 03-23-2023, 08:38 AM   #13
Mr. Dan's Avatar
None of my travel trailers/5th wheels have had hydraulic brakes/lines. Mine have all had electric brakes so just wires.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 36; Booked for 2023 = 28
Old 03-23-2023, 10:52 AM   #14
What kind of R/V do you have?
Hydraulic brakes with metal lines are rare from the factory on towables.
I see it was your 1st post and you don't have any information in your profile or a signature line.
Days Camped '19=110 '20=116 '21=123 '22=134 '23=93
Old 03-27-2023, 07:31 PM   #15
gw1800's Avatar
The battery in the trailer has nothing to do with the brakes when hooked up to the truck. It only control the brakes when the breakaway switch is pulled.
No brake power at the junction box on the trailer is either a bad cord, trailer plug or blown fuse in the truck if it has built in trailer brakes. It is possible the cord went bad if plug was pulled by the cord and not the housing.
Western PA
2015 Silverado Z71
2018 toy hauler
gw1800 is offline   Reply With Quote
Old 03-28-2023, 02:43 PM   #16
I retested voltages at the umbilical cable junction box.
Truck disconnected, on shore power, break away cable pin pulled:
Battery: 12.8v
Blue Brake wire: 12.25v
The difference here might be attributed to using frame ground vs battery lug.
Truck connected, on shore power, break away cable pin inserted:
Brake wire: 9.5v
Brake controller is set to maximum.
The voltage at the brake wire zeros when the controller paddles are released and the pin is inserted.
What should the brake controller voltage be? Where should I look next?
Since my prior post we had a different mechanic adjust the trailer brakes so they are tighter.
2020 Ford F-150
Old 03-28-2023, 03:10 PM   #17
gw1800's Avatar
Why are you checking while connected to shore power and truck connected? There should be no power on the brake wire while only on shore power.
Western PA
2015 Silverado Z71
2018 toy hauler
Old 03-28-2023, 03:47 PM   #18
When the truck is connected to the trailer, the TT and TV batteries are paralleled via the V+ and V- pins. Staying on shore power keeps the TT converter also paralleled keeping the batteries voltage constant.
2020 Ford F-150
Old 03-28-2023, 04:13 PM   #19
gw1800's Avatar
Battery power yes. Brake power should be not be aqffected. Sounds a though there is something in the trucks controller drawing down the voltage while connected.
The truck should be isolated from the TT power when the key is off so in fact the batteries are not in parallel. That stops the trailer from draining the trucks batteries.
Maybe it's me, but I always pull the trailer plug before hooking up shore power. Too many electronics involved in the truck and trailer.
Western PA
2015 Silverado Z71
2018 toy hauler
Old 03-28-2023, 04:37 PM   #20
Normally I do pull the umbilical cable before connecting shore power and only plug it back in after disconnecting.
To test the brake controller the truck requires being in the on position. Parrelling assured me of full power.
2020 Ford F-150
brakes
