Old 03-07-2019, 09:15 AM   #1
Oil filled hubs
Has anyone heard of retro fitting hubs on tt to oil filled hubs. I've had a dual axle boat trailer with oil filled hubs since 2005 and have had no problems. Just change oil once a year.
2020 Cedar Creek 38DBRK 5'r
2020 Chevy 2500HD Duramax 4X4
jimla is offline   Reply With Quote
Old 03-07-2019, 07:36 PM   #2
Failure is my business
2Evil4U's Avatar
I've never seen those before but I did find them on etrailer. Dexter makes a bunch of different ones. I'd expect if you found a set that was dimensionally correct for your spindles and brakes it would work fine.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 03-07-2019, 07:38 PM   #3
2Evil4U's Avatar
Have you had any issues with leaks over the years? I prefer oil lubrication to grease and if I ever need to redo my axles, I really like this idea.
Looks like Dexter only makes oil filled for 5500# and higher axles. Still like the idea. When I eventually upgrade in going to ask about this.
Old 03-08-2019, 09:02 AM   #4
I've only had to replace 1 seal since 2015
Old 03-08-2019, 11:57 AM   #5
That's because oil filled hubs tend to be larger than the standard cup and cone, grease lubed bearings on the smaller axles.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
led
