Ok to jack rear dually tires from axle???
Hello there. So my problem is when I use the recommended jack points on the frame of my Forest River 2400WS Mercedes class C RV, I can’t jack the rear dually tires off the ground! The leaf springs sage and I push the frame up, but not enough travel to get the tires up.
I’ve seen some videos for a product called safe jack and they put a U-shaped saddle right under the axle, and then jack from there. Looks great, but my question / concern is this an ok place to jack up my 12,000 pound RV? My rear axle is carrying about 8,000 lbs, so maybe 4,000 each side. Will jacking on the axle possibly bend or distort the axle?
I’m thinking this product is what I need, but I want to make sure I use it correctly and don’t damage my RV during the process.
Any thoughts?
Regards, John in Olympia, Wa.
