One tire going flat while parked.
It was the dam aluminum rim. It had a crack. Then the valve stem on spare was not replaced on my spare rim when they put my Hercules tire on it and we had a second flat!!! NOT OVERLOADED!! This is not my fault and could happen to anyone!!!!!I I check my weight, only dive 55-60 mph, check air pressure, lug nut torque, and tire condition. Thank God for Hercules tires and tire pressure monitors!! The tire was run flat twice and was still ok and we drove home for 4 hours on it. Due to the g rating it held up under duress. Pulled off as soon as alarms went off. Will be getting 20 ton bottle jack and flares. I used to carry all that with my TT. I have a 12 volt air pump. That is as stressed as I every was sitting on hwy with no shoulder trucks going by 80mph 2 feet away.my son said. “You guys enjoy a dangerous sport “.
