10-27-2020, 12:15 PM
Proper way to jack up trailer to service wheel bearings
Hello, Any advice on the proper way to jack up a two axle travel trailer to service wheel bearings? Is it ok to lift one wheel at a time? Don't see any info in my manuals and some people do it under the frame or under the axle in videos. Thanks for any advice.
10-27-2020, 12:23 PM
Head Rambler
It depends on whether you have spring hung axles or torsion axles.
For spring hung, most people place the jack either under the frame or under the spring perch on each axle.
For torsion axles you don't jack under the axle so under the frame is your option.
Having said that, if you have tandem axles some people use leveler ramps to lift one wheel at a time by running one wheel up on the ramp.
Gotta go campin!
10-28-2020, 06:29 PM
my TT and cargo trailer have double axles. I use wood pieces to drive on to get the tire of one side of one axle off the ground. Chock the remaing wheels !! That's the way I service my bearings and brakes. Repeat this process for all wheels, , ,
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
10-28-2020, 06:57 PM
I don't mean to sound disrespectful. Some folks that aren't mechanically inclined (not saying you are or not) can mess more up by disassembling their spindle bearings than helping. And I don't mean to imply that.
Maybe some that have experience can offer advice to help. Are you going to remove your bearings and flush/clean out all the old bearing grease and hand pack with new wheel bearing specific grease?
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
10-29-2020, 02:02 PM
Yes , I plan on repacking them myself, my concern is when jacking up on the frame behind the rear axles. I don't want to cause any unnecessary stress on the trailer. I've done bearing service on other trailers, never on a longer travel trailer.
10-29-2020, 02:22 PM
I chock the wheels and jack up the frame in two spots on one side of the trailer. Then I place 2 jack stands. This is the safest way and less stress on the trailer frame.
2019 Forester 2861DS
10-29-2020, 02:43 PM
As mentioned, on spring axles, pretty much everyone puts the jack under the bottom U-Bolt plate if the axles attach on top the springs. (underslung springs)
It's a little more tricky if the axle is under the springs (overslung springs) as there isn't much to jack against except a round axle tube or rounded U-Bolts. Depending on the head of your jack, it may be better then to jack on the frame.
I have torsion axles and since the axle attachment bracket is welded to the axle tube and bolted to the frame, (and holds the weight of the R/V) I jack against the bracket.
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=21
10-29-2020, 09:19 PM
Tundra 2014
Axle
On torsion axles, the safest way is a drive on ramp. I use the AndersenDrive on for lube and flat changes. Especially on the Ultra Lights, there just is not a lot of metal in the frame.
10-29-2020, 10:18 PM
Brake is on left
Bottle jack. Faster and easier than ramps. I do one at a time and put a jack stand under. Just in case.
10-30-2020, 03:37 AM
That is the way it is done, boyo!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
10-30-2020, 09:52 AM
ARLO
Camco sells something called a Trailer Aid regular and plus version. It takes 30 seconds to lift a wheel off the ground without jacks, jack stands, no laying on the ground. I got one and it is well worth the money. You drive one axle onto it and it raises the other wheel off the ground. Very convenient and secure.
11-03-2020, 09:24 AM
Here's how I raise ours with torsion axles.
I use a bottle jack on the frame where the axle mount is. Once I'm finished with the front wheel, I move the jack to the same spot on the rear axle mount.
11-14-2020, 06:02 PM
For the underslung type, is it okay to jack on the smallest leaf spring, right next to the axle? I didn't want to put the jack on the U bolt but the leaf spring seemed roughly equivalent and nice and flat.
[Edit] Never mind. I just found another post where this was asked and answered.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
11-23-2020, 12:13 PM
Winterizing/storing
Is it a good idea to store your trailer with the tires off the ground. Mine is a 30' Wolf-pack two axle toy hauler.
11-23-2020, 06:36 PM
Many tire manufacturers recommend taking the weight off a tire for storage.
The question is... how long is considered "storage."
I've successfully parked my utility and boat trailers, R/Vs (travel trailers 5th wheels and motorhomes) as well as other equipment and autos for many months WITHOUT lifting the tires off the ground, with no ill effects.
I think this is one of those "do what you are comfortable with" subjects.
Certainly if the tire is partially submerged in water or knee deep in mud may play a role in your decision making.
11-23-2020, 07:55 PM
I park the Forester on drive on rubber patio mats I believe are 2 x 2. Works for me. Previously parked TT on lawn along side of house or gravel at a storage place. Cover tires and have never noticed any bad effect on tires doing any of this. Having a vehicle up on jacks may make it more unstable in high winds. I would not want to consider the damage if it comes off the jacks.
