Our last coach was a Crusader 325. Put almost 10,000 miles on the original tries before they started to blow out. Changed to Maxxis and got 20,000 before they blew out. To go to bigger tires you have to change to 8 lugs and 110 lbs rims. Cheaper to buy Maxxis and change at the 16,000 mile mark.
One thing I changed that made a big difference was to go to a 7,000 lbs brake assembly. They bolt right on even though the current assembly is only 5,200 axles. Also changed the brake wire from 12 to 10 gauge. You step on the brakes, the coach stops, no questions asked.
18 Berkshire 34QS, 2023 Jeep Grand Cherokee.
