Originally Posted by Curly2001
I am sorry if this is a duplicate post but I don't see the one I just did. Just curious to see how many times you can torque a bolt? I have to lower my Curt hitch a hole and re-torque the bolts but don't want to have a problem. Didn't know if there is a rule of thumb on how many times you can torque a bolt before it becomes unusable. They only require 100 ft.lbs. of torque.
Thanks in advance,
Curly
There all bolts that have to be changed after one use, they are called "torque to yield" bolts and are commonly used on cylinder heads, engine internals and other high strength applications. They are tightened to a certain spec (often length, not torque), which causes them to stretch a precise amount and provide clamping force. Once tension is relieved that elasticity is gone and the bolt is scrap.
The standard hardware we typically use doesn't work that way, and it's OK to loosen and re-torque without concern (within reason of course, and without over-tightening). Think how many times a car's wheels get removed/installed in its lifetime, the studs are designed to take it.
