Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-13-2021, 05:07 PM   #1
Replace just one tire?
We purchased our Grey Wolf 22RR Toy Hauler two years ago and is our first TT. This past week we had a tire blow out and the tire totally disintegrated. There was nothing left and the old tire wrapped around the axle. We were traveling about 65 with a load of about 1800 lbs. Its rated for 2500 lbs.
I assume the stock tires, Castle Rock ST205/75R14, 8PR load range, D105/101L, are fairly cheap tires? I think maybe they are only 6 ply tires as it says 2 ply tread, 2 wire ply and 2 sidewall ply.
Obviously, I need to replace the tire that disintegrated, but should I replace all 4? I would rather spend more money and avoid problems on the road. If I replace all 4 what should I get? Again, I'm willing to spend the money to avoid problems on the road.
Thanks in advance for any help!
betakidd is offline   Reply With Quote
Old 11-14-2021, 02:03 AM   #2
Guspech750's Avatar
We bought our 2021 Grey Wolf in March. Came with Castle Rock tires. Took it on many short 1.5 to 3 hour weekend trips 2-3 times a month with a few trips to Cleveland area. When August rolled around and it was time for our 16 day trip to Wyoming. I had all 4 tires replaced with much better quality Goodyear Endurance tires even though the Castle Rocks looked fine . I did keep two Castle Rocks and had one mounted on a spare rim.
I guess my point is replace them all with a better quality tire. You’ve got your use out of the Castle Rocks.
Tow vehicle: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
Guspech750 is online now   Reply With Quote
Old 12-01-2021, 04:33 PM   #3
X2
2021 Coachmen Spirit 1943RB
2021 Toyota Tundra Crewmax
Aspendog is offline   Reply With Quote
Old 12-02-2021, 11:56 AM   #4
I had a blow out two weeks ago on 1 year old castle rocks. I never like the idea of 14" wheels, so i replaced them with 225/75/15. Order through etrailer and got them in 2 days.
ID:	266344   Click image for larger version
2020 Gray Wolf 26RR
2016 Tundra TRD Pro
edc1911 is online now   Reply With Quote
Old 12-02-2021, 12:19 PM   #5
njfishing's Avatar
You are already going to be in for $100 on one tire and be on edge until you replace the others. For me, the additional $300 would be worth the peace of mind.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is offline   Reply With Quote
Old 12-02-2021, 12:28 PM   #6
if you can buy GOOD ST tires for that price you're VERY luck. four 235/16 Good Year Endurance tires just cost me over $200.00 each out the door.
nayther is offline   Reply With Quote
Old 12-03-2021, 08:05 AM   #7
SeaDog's Avatar
There are many different schools of thought on this subject. As a minimum (this is just opinion) replace both on the side that had the blowout. One failed and the other tire carried the entire load and may have suffered and be the next to go. JMHO I have always said tires are cheap insurance.
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-03-2021, 08:20 AM   #8
I wanted the peace of mind, so I bought 4 Goodyears and increased size one step from 205 to 215
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 12-03-2021, 08:33 AM   #9
njfishing's Avatar
This is exactly what happen to me... I had a blow out and put on my spare. I immediately drove to the closest tire shop around 20 miles away to get the spare replaced. When I arrived, I noticed the other tire on the same side had some steel belts showing and it had to be replace it as well..
Gerry Z
Curt Trutrack WDH
Old 12-03-2021, 08:34 AM   #10
At a minimum (per Seadog) you should look at replacing two on the failed side, since one tire was overloaded for an unspecified amount of time. You will likely havet many saying replace all as CastleRocks are crap, ticking bombs, sign of Armageddon, etc.
I've not had issues with OEM tires, but I don't choose them as replacements either. There are quite a few stories on this site and others where OEM tires were involved in failures.
2016 Roo 21SS, 2016 F150
2015 Rockwood 2514G (pup), 2015 Fd Expl,
2003 Coleman Utah (pup), 2007 Fd Expl
Underthedog is offline   Reply With Quote
Old 12-03-2021, 09:02 AM   #11
njfishing's Avatar
Mine were Castle Rocks as well and I did the same but went up one load range from D to E giving me a little more wiggle room. I figured if one tire blows, the others would carry the increased load better.
Gerry Z
Curt Trutrack WDH
Old 12-03-2021, 09:37 AM   #12
wmtire's Avatar
I know this thread is several weeks old but want to clarify about ply ratings....which will not be the actual ply count.
The historical term ply rating goes back to the days when bias ply tires were actually constructed of layer upon layer of cotton fabric — yes, cotton. Ply rating referred to how many layers, or plies, of cotton had been used in the tire's construction, and the number of plies determined the strength of the tire.
In today's modern world, tire plies are no longer made out of cotton. Now, tires are constructed using fewer, yet much stronger, plies so the term ply rating doesn't refer to the actual number of plies anymore. Instead, the ply rating indicates an equivalent strength compared to early cotton-constructed bias ply tires.
If you see ply rating and load range on a chart, they both represent the tire's maximum load carrying capacity at maximum allowable air pressure.
2011 Flagstaff 831 RLBSS
Golf ball-sized hail wouldn't be as destructive if golf balls were just made smaller.
Old 12-03-2021, 10:36 AM   #13
Retired Army MSG!
lazyjj's Avatar
Removed my Castle Rocks before they had time to blow. In my humble opinion change them all.
lazyjj is online now   Reply With Quote
Old 12-05-2021, 06:44 PM   #14
This is what most of us have done. You need to replace all the garbage China bombs with GY E's. May as well go up in size and LR too.
krazyk is offline   Reply With Quote
tire
