Closed Thread
Old 01-27-2019, 03:35 PM   #1
Replacing Nitrofill for Compressed Air
With the lack of dealership availability and high cost of refills, Iíd like to completely replace the nitrogen fill tires with compressed air instead. However, thereís little to be found on the whynitrofill.com website about doing away with it so looking for any tips from those that have done this on their Forest Rivers as well.
Thank you!
Duncan & Carol
DuncanMc is offline
Old 01-27-2019, 03:44 PM   #2
wmtire's Avatar
Originally Posted by DuncanMc View Post
With the lack of dealership availability and high cost of refills, I’d like to completely replace the nitrogen fill tires with compressed air instead. However, there’s little to be found on the whynitrofill.com website about doing away with it so looking for any tips from those that have done this on their Forest Rivers as well.
Thank you!
Duncan & Carol
All nitrofill is, is where the regular air we breath is filtered to get a little more nitrogen content (90-95%). Normal air is already 78% percent nitrogen.
Just air up your tires when needed with regular air, and you will be fine. No need to change anything.
https://www.tirerack.com/tires/tiret...jsp?techid=191
https://www.consumerreports.org/cro/...tudy/index.htm
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
wmtire is offline
Old 01-27-2019, 03:46 PM   #3
SecretSquirrel's Avatar
Thank you!
Duncan & Carol
I believe you can just use regular air as needed. No need to "replace" the nitrogen. Air is 78% nitrogen anyway.
EDIT - I see wmtire posted while I was slowly pecking away on the iPad keyboard.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline
Old 01-27-2019, 04:33 PM   #4
B and B's Avatar
I would look at using Helium instead. Removes road wear on the tires and they float over bumps better.
B and B is offline
Old 01-27-2019, 04:45 PM   #5
Charging people to fill their tires with nitrogen i one of the biggest scams ever unleashed on the public. The salesmen should be charged with fraud.
Don't worry about removing the nitrogen, just keep your tires topped off with regular old breathable air.
BarabooBob is offline
Old 01-27-2019, 05:37 PM   #6
A32Deuce's Avatar
Same as changing out summer air for winter air. So it won't freeze!
A32Deuce is offline
Old 01-27-2019, 05:41 PM   #7
SailorSam20500's Avatar
I did the summer for winter air change last month. This month's job - top up the blinker fluid.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline
Old 01-27-2019, 05:45 PM   #8
Denver To Yuma In 90 Days
Plus...it makes road noise from the tires sound like Alvin and the Chipmunks!
JohnD10 is offline
Old 01-27-2019, 05:53 PM   #9
DavidBo's Avatar
Make sure you only use the finest synthetic blinker fluid!
Actually, this horse has already been beaten well beyond death in this forum, do a quick search and you'll have every answer you need, and three times as many that you don't!
DavidBo is offline
Old 01-27-2019, 06:47 PM   #10
Unencumbered By The Thought Process
tande is offline
Old 01-28-2019, 01:20 PM   #11
Dahagen
Try hydrogen. It will give you more lifting power.
dahagen is offline
Old 01-28-2019, 01:35 PM   #12
Mr. Dan's Avatar
OP, see post #2 for your answer.
Recess is over.
Thread closed.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Mr. Dan is offline
Closed Thread
