Originally Posted by cdn1972
I have no problem with that and agree TT disturb way more air being towed but the question is with TT can reduced rolling resistance help?
If it does you'll never be able to measure it.
Bearings are an inch or two in diameter and tires are over two feet in diameter. Any resistance in the bearing due to grease is overcome by the mechanical advantage created by the tire diameter vs bearing diameter.
Might be able to measure benefit in a lab but will it translate to easier towing?? Only in one's mind.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
