Originally Posted by donvt
We have a single axle Wolf Pup. I have read about these used on cars. Since I do not the second axle in case of a massive blow out I do not have a back up wheel to safely stop. I have researched tire pressure monitor and if a slow leak then they will work. I just want to be able to get to a safe place to change the tire. Any thoughts or experience with this type of tire?
If you get the right TPMS they will tell you of fast leaks too. My TST 507 will trigger the alarm as close to instantly if I screw it off the stem.
