Originally Posted by guyster
Put some rollers on it...
only if you want frame damage.... the camper is not designed to hold the weight by the rear of the frame.
The point of those skid plates is to warn you that you are out of ground clearance.
Is the nose of the camper too high or are you driving in areas with lots of slope changes?
The only good fix to this (besides finding better roads) is to change the axle setup so the camper rides higher.
