04-07-2019, 09:45 PM
Slide out seal lubricants
Hi everyone! Just wanted to gather some opinions on the type of slide out seal lubrication methods you use and why? Have heard some use spray lube while others just use baby powder! What do you use and why do you use it?
04-07-2019, 09:54 PM
This would depend upon the type of slide mechanism to some extent. The LCI slides that I have in my unit, say to only use dry spray lub with PTFE, so that is what I use. But the gear pack that guides the slide, says to lub with synthetic 10w30 so I carry a oil can with the oil in it to lub the gear packs.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
04-08-2019, 07:34 AM
You can use 303 on the slide seals.
04-08-2019, 08:27 AM
I don't use anything on any slide seals. Never have on any RV. Our current rig is 7 years old and seals are fine, even out here in the Southwest.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-08-2019, 08:46 AM
Kanadian Kamper
I believe the original post is asking about “seal lubrication” not the different power mechanisms for driving the slides in and out.
Ken and Terry
04-08-2019, 09:22 AM
I've always used Aerospace 303 on the rubber seals.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
04-08-2019, 12:30 PM
I have a 2012 and only use spray foot powder on my seals. Seals are still great after 7 years and they don't have athletes foot or stink.
04-08-2019, 12:51 PM
LOL! Now that there is funny
04-08-2019, 03:06 PM
X3 on Aerospace 303. Got an aluminum extension pole and made a pad on the end with a T-shirt and tape to reach the seal under the slide topper.
Bought a gallon on amazon for $38 to refill the quart spray bottle.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
04-08-2019, 04:24 PM
Old Engineer
I use 303 Protectant on a sponge or any brand Silicone Spray in the can.
The sponge is on a dowel so I can reach under the slide toppers from either side.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
04-08-2019, 04:50 PM
Camping with Labs
Another "vote" for 303 here. With the slides partially closed I can reach all the inside seals. With the slides fully open, and with the help of a ladder, I can reach the outer sides and most of the top seals that reside under the slide covers. For the middle section of the outer top seals, I use a small sponge mop with a microfiber cover over it. Once or twice a year is all it takes.
Chris, Paula, & camping Labs, Shasta (RIP 8/10/20) & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS with Hensley Arrow Hitch
04-08-2019, 07:45 PM
New to FR. Old to TT
X2 above, uv protection and slick surface that won't attract dust or dirt. Has helped my slide go in and out more smoothly.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
04-09-2019, 04:51 AM
X2. Softens them and helps protect from UV degradation. GOOD STUFF!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
04-09-2019, 08:08 AM
Originally Posted by Iwritecode
This what I use
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
04-09-2019, 08:18 AM
I use the 303 on the seals as well and the dry lubes with ptfe on the mechanism
The black painted flashing at the outer edge of the slides is built with a mitered corner to the sheet metal on the top. On the inside, a piece of eternabond covers the seam of that mitered edge. In the heat of summer ,that black sheet metal will get hot enough that the eternabond will migrate and the adhesive will ooze. Keep an eye on it and remove that ooze OR when you close your slide and it can stick to your upper slide seals at the ends and the seals can be torn at the ends. Know how I know this? I had to have both seals replace on both slides last fall on a 3 yr old tt. On each end the seals were torn about 8 in. $$
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-09-2019, 08:23 AM
X2
2014 35 V-Lite 30WIKSS Platinum
Expedition 5.4, Hankook, Reese 1200 Round Bar, Trans-Go, Hadden, Curt Tri-Flex, 3.73 Posi-Traction
04-09-2019, 08:24 AM
I use 3&1 slide seal lube from Walmart 3 or 4 times a year. Those seals are expensive to replace.
2017 Wildwood 30KQBSS
2019 F-250 XLT 4x4 crew 6.2L
04-09-2019, 09:04 AM
I use Thetford slide out rubber seal conditioner on recommendations of my dealer.
https://www.amazon.com/Premium-Slide.../dp/B000NJ6EZ8
Unknown if one is better than other. Both available from Amazon
Will probably switch to cheaper cost (get more for less). Thank-you!
Protect All Thetford Corp 40015 Rubber Seal Treatment 17 Oz at $10.80
Premium RV Slide Out Rubber Seal Conditioner Protectant 14 oz Thetford 32778 $13.90
04-09-2019, 09:22 AM
Do you have a link for that? I've seen the window lubricant, and the silicone spray lube for the for the gears and rails, but nothing for the seals.
PS>.. Love your username... I always joke with my DW that I'm "Driving Miss Becky..." LOL
Brian & Becky
2018 Avenger ATI 27RBS
