Old 03-29-2024, 12:27 PM   #1
PhilSR5's Avatar
Spare tire carrier on Azdel panel
Hi folks
For better weight distribution I want to mount a spare wheel carrier on the rear panel of a Freedom Express 20SE.
I don't want it under the frame as there is enough ground clearance and I can't either use the bumper carrier style because of 0 clearance between bumper and rear panel of the trailer
So solution I'm thinking of is to mount the carrier plate directly onto the rear panel (Azdel) and add another plate inside the trailer. The 15'' tire would then sit just above the bumper , all comments or recommendations about this possible solution are welcome!
Cheers
Phil
PhilSR5 is offline   Reply With Quote
Old 03-29-2024, 12:33 PM   #2
llr
Personally unless I could catch a beam between the bolts or bolts going through the beam I would not do it.
With the right temperature. and humidity it is easy to see the beams
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 03-29-2024, 12:50 PM   #3
PhilSR5's Avatar
Thank you, I want to use an L bracket inside the trailer so I can have it bolted to the floor as well, it's inside the storage compartment under dinette bench ...
2021 Freedom Express 20SE - 2018 Toyota Tundra SR5
panel, tire
